Fix on Scroll for mobile menu
oliver.sartor
oliver.sartor posted this 20 February 2017
Hello Support,
I don't find in my Themler Version (v.355) the "Fix on Scroll-Function". When I have a horizontally menu and
I go to the expansions there isn't the function. You can see it in the "Screenshot-1". In the other forum articles I can't
find the right solution. I have antoher question. How I can use the "Fix on Scroll" for the mobiles (repository) menu.
There I can't find a solution, too!
Best regards
Oliver Sartor!
Hello Support, I don't find in my Themler Version (v.355) the "Fix on Scroll-Function". When I have a horizontally menu and I go to the expansions there isn't the function. You can see it in the "Screenshot-1". In the other forum articles I can't find the right solution. I have antoher question. How I can use the "Fix on Scroll" for the mobiles (repository) menu. There I can't find a solution, too! Best regards Oliver Sartor!
Support Team posted this 21 February 2017
Please use the Sticky extension, then also check in the Sticky drop down options that it is enabled for the mobile phone mode.
Hi, Please use the Sticky extension, then also check in the Sticky drop down options that it is enabled for the mobile phone mode. Sincerely, Hella
oliver.sartor
oliver.sartor posted this 21 February 2017
Hello, I have another question. Can you give me a screenshot to show me how to to create an anchor in Themler? When I use a HTML-Box with the HTML-Code vor anchors it doesn' t work. Best regards Oliver Sartor
Support Team posted this 22 February 2017
Please follow the instructions in this article:
http://answers.themler.com/articles/5582/one-page-design-in-joomla
Hi, Please follow the instructions in this article: http://answers.themler.com/articles/5582/one-page-design-in-joomla Sincerely, Hella
oliver.sartor
oliver.sartor posted this 23 February 2017
this link is not helpful because you can see in the screenshoot "Anchor_1" where I have inserted a html area.
This was my html-code. "<div id></div>". But when I insert this, how it is is shown in the example, you can
see the html-code in the homepage. This you can se in the screenshot "Anchor_2". How I can hidden this code?
Best regards
Oliver Sartor
Hello, this link is not helpful because you can see in the screenshoot "Anchor_1" where I have inserted a html area. This was my html-code. "&lt;div id&gt;&lt;/div&gt;". But when I insert this, how it is is shown in the example, you can see the html-code in the homepage. This you can se in the screenshot "Anchor_2". How I can hidden this code? Best regards Oliver Sartor
Support Team posted this 24 February 2017
Do not insert the code directly in the control. Use the top ribbon option HTML >> HTML Source and insert the code in that window.
Hi, Do not insert the code directly in the control. Use the top ribbon option HTML >> HTML Source and insert the code in that window. Sincerely, Hella
