Joomla - Sliders Grow/Shrink Issue
ABSolutions
ABSolutions posted this 22 February 2017
Hi Themler,
Working on a site and I am using a plugin called "Anything Sliders", which allows we to add sliders to an article within Joomla. The sliders work fine and push the footer down when the grow, but when they shrink the footer does not shrink back with the action (see screenshots). I have used this pluggin on many sites (including Artisteer generated themed sites) and haven't had this problem in the past. Any idea how to correct the problem? I want the footer to come back up after a slider has been collapsed.
Hi Themler, Working on a site and I am using a plugin called "Anything Sliders", which allows we to add sliders to an article within Joomla. The sliders work fine and push the footer down when the grow, but when they shrink the footer does not shrink back with the action (see screenshots). I have used this pluggin on many sites (including Artisteer generated themed sites) and haven't had this problem in the past. Any idea how to correct the problem? I want the footer to come back up after a slider has been collapsed.
21 Comments
Support Team posted this 27 February 2017
Please provide a link to your site.
Hi, Please provide a link to your site. Sincerely, Hella
ABSolutions
ABSolutions posted this 27 February 2017
The site is located here:
http://www.epcjobs.ca/reboot
You can find a page with the sliders here:
http://www.epcjobs.ca/reboot/employers
Cheers,
AB
The site is located here: http://www.epcjobs.ca/reboot You can find a page with the sliders here: http://www.epcjobs.ca/reboot/employers Cheers, AB
Support Team posted this 28 February 2017
Try to add the following code under the Home >> Settings >> Additional CSS:
.separated-item-38.col-md-12.first-col.last-row.last-col {
    min-height: 100px!important;
Hi, Try to add the following code under the Home >> Settings >> Additional CSS: .separated-item-38.col-md-12.first-col.last-row.last-col { min-height: 100px!important; } Sincerely, Hella
ABSolutions
ABSolutions posted this 28 February 2017
Fantastic! That fixed it.
Cheers,
AB
Fantastic! That fixed it. Cheers, AB
You are welcome. Feel free to contact us again.
You are welcome. Feel free to contact us again. Sincerely, Hella
ABSolutions
ABSolutions posted this 01 February 2018
Hi Themler,
Same issue here:
http://www.ptbomusicfest.ca/about/board-of-directors
But, the CSS above doesn't fix it.
Hi Themler, Same issue here: http://www.ptbomusicfest.ca/about/board-of-directors But, the CSS above doesn't fix it.
Support Team posted this 02 February 2018
The classes a little different now:
.separated-item-46.col-md-12.first-col.last-row.last-col {...}
Hi, The classes a little different now: `.separated-item-46.col-md-12.first-col.last-row.last-col {...}` Thank you, Olivia
ABSolutions
ABSolutions posted this 02 February 2018
Awesome! It works...thanks a bunch.
ABSolutions
ABSolutions posted this 22 March 2018
Still having the same issue here:
http://www.peterboroughwolverines.ca/teams/bantam#coaching-staff
AB
Still having the same issue here: http://www.peterboroughwolverines.ca/teams/bantam#coaching-staff AB
Support Team posted this 22 March 2018
I cannot reproduce the issue. White space is being reduced when the new tab is clicked.
Hi, I cannot reproduce the issue. White space is being reduced when the new tab is clicked. Sincerely, Hella
ABSolutions
Sorry - not working in Firefox or Safari on Mac.
AB
Sorry - not working in Firefox or Safari on Mac. AB
I see it now. Please try this code:
    min-height: 200px !important;
Hi, I see it now. Please try this code: .separated-item-38.col-md-12.first-col.last-row.last-col { min-height: 200px !important; } Sincerely, Hella
ABSolutions
Is Solution
Awesome! Thanks.
Awesome! Thanks.
Support Team posted this 23 March 2018
You're welcome. Please let us know if you need our further assistance.
Themler Team
Hi, You're welcome. Please let us know if you need our further assistance. Thank you, Themler Team
ABSolutions
ABSolutions posted this 03 August 2018
Having the same issue with a WordPress Themler Theme here http://develop.absweb.ca/bring-your-own-device/
Support Team posted this 06 August 2018
The solution is the same in this case also. But the class is a little different: .bd-grid-6 .separated-item-21{...}
Hi, The solution is the same in this case also. But the class is a little different: `.bd-grid-6 .separated-item-21{...}` Thank you, Olivia
ABSolutions
ABSolutions posted this 07 August 2018
So is this correct:
.bd-grid-6 .separated-item-2.col-md-12.first-col.last-row.last-col {
AB
So is this correct: .bd-grid-6 .separated-item-2.col-md-12.first-col.last-row.last-col { min-height: 200px !important; } AB
ABSolutions
ABSolutions posted this 10 August 2018
Ok - I have tried this a few ways, but I am still having issues. The latest I tried is:
.bd-grid-6 .separated-item-21{ min-height: 200px !important;
But, no luck - check here:
http://develop.absweb.ca/2018/05/25/the-samr-model/
Ok - I have tried this a few ways, but I am still having issues. The latest I tried is: .bd-grid-6 .separated-item-21{ min-height: 200px !important; } But, no luck - check here: http://develop.absweb.ca/2018/05/25/the-samr-model/
Support Team posted this 13 August 2018
In case of the page you provided the proper selector is .bd-grid-5 .separated-item-34{...}.
Do you know how to use browser developer tools? If you you can use web inspector to find the classes manually.
Hi, In case of the page you provided the proper selector is `.bd-grid-5 .separated-item-34{...}`. Do you know how to use browser developer tools? If you you can use web inspector to find the classes manually. Thank you, Olivia
