something wrong with columns in article (shortcodes in joomla)
Barbora K.
Barbora K. posted this 27 February 2017
Hi!
I have some issue with shortcodes. I am trying to have two columns in my article, the best would be the 33% and 66% layout, so I decided to use "thirds" as you may see bellow. But as a result I get this: http://zameckeapartmany.cz/cs/kontakt
Could you please help me?
<p>[one_third]<img src="images/Iva_Voriskova.jpg" alt="" />[/one_third] </p>
<p> </p>
<p>[two_third]</p>
<p><strong>Ivana Voříšková</strong>, provozní apartmánu<br /> tel. 725 981 646, <a href="mailto:recepce@smetanovalitomysl.cz">recepce@smetanovalitomysl.cz</a></p>
<p><strong>Smetanova Litomyšl,o.p.s.</strong><br /> Jiráskova 133 (zámek)<br /> 570 01 Litomyšl</p>
<p>GPS: 49°52'22,93"N, 16°18'49,7"E</p>
<p> </p>
<p> [/two_third]</p>
Barbora
Hi! I have some issue with shortcodes. I am trying to have two columns in my article, the best would be the 33% and 66% layout, so I decided to use "thirds" as you may see bellow. But as a result I get this: http://zameckeapartmany.cz/cs/kontakt Could you please help me? <p>[one_third]<img src="images/Iva_Voriskova.jpg" alt="" />[/one_third] </p> <p> </p> <p>[two_third]</p> <p><strong>Ivana Voříšková</strong>, provozní apartmánu<br /> tel. 725 981 646, <a href="mailto:recepce@smetanovalitomysl.cz">recepce@smetanovalitomysl.cz</a></p> <p><strong>Smetanova Litomyšl,o.p.s.</strong><br /> Jiráskova 133 (zámek)<br /> 570 01 Litomyšl</p> <p>GPS: 49°52'22,93"N, 16°18'49,7"E</p> <p> </p> <p> [/two_third]</p> Thanks Barbora
Support Team posted this 27 February 2017
I suggest that you open this article in Themler and add Columns control with the desired columns configuration:
This should help.
Hi, I suggest that you open this article in Themler and add Columns control with the desired columns configuration: !article-with-columns.png! This should help. Please keep us posted about the progress. Thank you, Olivia
Barbora K.
Awesome! Thanks :-) Regarding the editor there was some third column with 100% width and it probably pushed the other columns down. I had no idea I can work on single article layout in Themler, you guys are amazing!
Thank you again
Barbora
Awesome! Thanks :-) Regarding the editor there was some third column with 100% width and it probably pushed the other columns down. I had no idea I can work on single article layout in Themler, you guys are amazing! Thank you again Barbora
Support Team posted this 28 February 2017
This feature is available for WP and joomla themes only. All content added to the CMS content area (green area) will be converted to shortcodes and added to the opened CMS page/post content.
You can add any html controls (section, column, text, image, etc).
Please let us know if you have any other questions/issues.
Hi, This feature is available for WP and joomla themes only. All content added to the CMS content area (green area) will be converted to shortcodes and added to the opened CMS page/post content. You can add any html controls (section, column, text, image, etc). Please let us know if you have any other questions/issues. Thank you, Olivia
