404 Error - Page Not Found
Seagull Experts®
Seagull Experts® posted this 01 March 2017
Offline HTML5 page visible, however after upload gives shows 404 Error - Page Not Found.
Tried un-installation and reinstalled same version by downloading same program. (Themler.1.0.319.fe25b)
Offline HTML5 page visible, however after upload gives shows 404 Error - Page Not Found. Tried un-installation and reinstalled same version by downloading same program. (Themler.1.0.319.fe25b)
Support Team posted this 02 March 2017
Could you please try to export the theme anew with "Include Themler" option enabled, and attach it here for investigation? I have moved the case to private.
Hello, Could you please try to export the theme anew with "Include Themler" option enabled, and attach it here for investigation? I have moved the case to private. Sincerely, Nettie, BillionDigital Team
Seagull Experts®
Seagull Experts® posted this 04 March 2017
Kindly check attached zip file.
Support Team posted this 06 March 2017
The issue is fixed, please try updating to the latest Beta version. You may need to check the box next to "Get Beta updates" in your profile to receive the Beta update notification. After installing the Beta update you may uncheck the box at any time.
Hello, The issue is fixed, please try updating to the latest Beta version. You may need to check the box next to "Get Beta updates" in your profile to receive the Beta update notification. After installing the Beta update you may uncheck the box at any time. Sincerely, Nettie, BillionDigital Team
Nuve
Nuve posted this 23 March 2018
Hi there
I am having the some issue even with the themler custumazation ticked option any clue?
Hi there I am having the some issue even with the themler custumazation ticked option any clue?
Support Team posted this 23 March 2018
Do you get the error with Themler for HTML as well? Does it happen with any theme including a new theme or with some specific theme?
Hello, Do you get the error with Themler for HTML as well? Does it happen with any theme including a new theme or with some specific theme? Sincerely, Nettie, BillionDigital Team
