Horizontal sub-menu
TSMM
TSMM posted this 20 May 2015
I'd like to have the submenu of the main menu layout horizontal not vertical. Is that possible.
Example: http://johnflynn.org/index.shtml
I'd like to have the submenu of the main menu layout horizontal not vertical. Is that possible. Example: http://johnflynn.org/index.shtml
Support Team posted this 20 May 2015
Unfortunately such type of Horizontal menu subitems is not supported at this time. But I've added your request to our wish list.
Hi, Unfortunately such type of Horizontal menu subitems is not supported at this time. But I've added your request to our wish list. Thank you, Olivia
TSMM
TSMM posted this 27 May 2015
Ok, Thanks.
Ok, Thanks.
jorgemfernandez
jorgemfernandez posted this 11 August 2017
I trying to put a horizontal sub-menu like another people, i'm seeing that a lot of people need the same but since 2 years ago (aprox) the answer is always the same, " I've added your request to our wish list" but we are on 2017 August and this functionallity is not added, are we paying for a program without updates? i donĀ“t understand why you don't implement this function, and less before 2 YEARS, are you an enterprise or a single user from his house trying to do a little bit money?
I trying to put a horizontal sub-menu like another people, i'm seeing that a lot of people need the same but since 2 years ago (aprox) the answer is always the same, " I've added your request to our wish list" but we are on 2017 August and this functionallity is not added, are we paying for a program without updates? i don´t understand why you don't implement this function, and less before 2 YEARS, are you an enterprise or a single user from his house trying to do a little bit money?
Support Team posted this 11 August 2017
Looks like you want to have the functionality like a megamenu? It is implemented in Themler. To activate the Megamenu functionality you need to select that menu type inside Themler >> Horizontal menu options. Do not forget that this functionality works only when you have 3 levels in menu or more.
Hi, Looks like you want to have the functionality like a megamenu? It is implemented in Themler. To activate the Megamenu functionality you need to select that menu type inside Themler >> Horizontal menu options. Do not forget that this functionality works only when you have 3 levels in menu or more. Sincerely, Hella
