Custom Post Types
info1496
info1496 posted this 13 March 2017
Ok, this might be a basic question, but can I somehow create my own custom post types within Themler?
I don´t mind creating the functions code myself but then I face the problem that additional CMS code doesn´t seem to work for the backend.
Do I really need to use a plugin for this??
Ok, this might be a basic question, but can I somehow create my own custom post types within Themler? I don´t mind creating the functions code myself but then I face the problem that additional CMS code doesn´t seem to work for the backend. Do I really need to use a plugin for this??
Support Team posted this 14 March 2017
The most recent Beta update
http://answers.themler.com/questions/122312/themler-v-358-beta-update-2-march-2017
allows creating Custom Post Types by adding custom code to the Themler Settings >> Additional CMS Code.
Hi, The most recent Beta update http://answers.themler.com/questions/122312/themler-v-358-beta-update-2-march-2017 allows creating Custom Post Types by adding custom code to the Themler Settings >> Additional CMS Code. Thank you, Olivia
info1496
info1496 posted this 14 March 2017
Thank you!
Any idea on when this will be an official release?
I really don`t want to use a beta version on a customer project
Thank you! Any idea on when this will be an official release? I really don`t want to use a beta version on a customer project
Stagger Lee posted this 14 March 2017
It is not something Themler should do. You mix functions and design.
info1496
CPT are usually defined in functions.php. I just want to add my cpt function to functions.php but it won´t work through Themler. No need for any design options - just a proper working functions.php like in any regular theme
> It is not something Themler should do. You mix functions and design. CPT are usually defined in functions.php. I just want to add my cpt function to functions.php but it won´t work through Themler. No need for any design options - just a proper working functions.php like in any regular theme
info1496
will try a Site-Specific WordPress plugin for that
Make your own functions plugin, not big deal.
  • New subfolder in plugins folder.
  • folder-name
  • New php file inside folder-name folder
  • Rename it to folder-name.php
  • Activate in WP backend.
  • It is all, just change names tu suit you.
Starter code needed for folder-name.php:
<?php
 * Plugin Name: Custom Functions
 * Plugin URI: http://www.some-website.com
 * Description: This is an awesome custom plugin with functionality that I'd like to keep when switching things.
 * Author: Some Author
 * Author URI: http://www.some-website.com
 * Version: 0.0.1
/* Place custom code below this line. */
/* Place custom code above this line. */
Make your own functions plugin, not big deal. - New subfolder in plugins folder. - folder-name - New php file inside folder-name folder - Rename it to folder-name.php - Activate in WP backend. - It is all, just change names tu suit you. Starter code needed for folder-name.php: <?php /** * Plugin Name: Custom Functions * Plugin URI: http://www.some-website.com * Description: This is an awesome custom plugin with functionality that I'd like to keep when switching things. * Author: Some Author * Author URI: http://www.some-website.com * Version: 0.0.1 */ /* Place custom code below this line. */ /* Place custom code above this line. */ ?>
info1496
Thank you... just did. Never thought of an alternative to functions.php but it makes sense in so many cases.
