Create a template with joomla
doganayemrah
doganayemrah posted this 20 March 2017
hi,
http://demo4.mixwebtemplates.com/?template=mx_joomla137
How can I make the above template with "themler"?
There is no user manual.
Notify to us. You said help me.
Yeah . How it is made?
We have not been able to use "themler" since July.
Thank you.
hi, http://demo4.mixwebtemplates.com/?template=mx_joomla137 How can I make the above template with "themler"? There is no user manual. Notify to us. You said help me. Yeah . How it is made? We have not been able to use "themler" since July. Thank you.
Support Team posted this 21 March 2017
In general, you can create such theme in Themler. But there are a few things that Themler does not support: exactly this animation effect of the 5 blocks with round images, slideset with square image at the bottom (5 blocks), scale of the whole block on hover (slideset in the right sidebar).
The other parts are quite simple, except the Footer. It requires some css skills.
Themler provides a number of similar Header Sections with full screen Slider. Most of sample Slider Sections are configured in the desired way when full page Slider appears on the Home template only.
Below if the content area with Sidebars. To create it simply enable Content & Sidebars under the Insert tab and add desired number of sidebars. Below is a Section with blue background where you can add "joomla position" controls for Joomla modules. Each joomla position may have own module styling. This Section should be added on the Home template only.
The grey area at the bottom if the Footer with fixed position. This footer requires basic css skills for proper configuration. Themler does not provide such effect by default.
The controls with orange border is the special controls used to share controls between templates.
The area with blue borders is the part of the opened template.
The area with green border is CMS content editing area.
Please let us know if you have any specific questions.
Hi, In general, you can create such theme in Themler. But there are a few things that Themler does not support: exactly this animation effect of the 5 blocks with round images, slideset with square image at the bottom (5 blocks), scale of the whole block on hover (slideset in the right sidebar). The other parts are quite simple, except the Footer. It requires some css skills. Themler provides a number of similar Header Sections with full screen Slider. Most of sample Slider Sections are configured in the desired way when full page Slider appears on the Home template only. Below if the content area with Sidebars. To create it simply enable *Content & Sidebars* under the Insert tab and add desired number of sidebars. Below is a Section with blue background where you can add "joomla position" controls for Joomla modules. Each joomla position may have own module styling. This Section should be added on the Home template only. The grey area at the bottom if the Footer with fixed position. This footer requires basic css skills for proper configuration. Themler does not provide such effect by default. The controls with orange border is the special controls used to share controls between templates. The area with blue borders is the part of the opened template. The area with green border is CMS content editing area. Please let us know if you have any specific questions. Thank you, Olivia
DaveOzric
DaveOzric posted this 21 March 2017
Are you planning on adding some more animation effects to Themler?
> n general, you can create such theme in Themler. But there are a few things that Themler does not support: exactly this animation effect of the 5 blocks with round images, slideset with square image at the bottom (5 blocks), scale of the whole block on hover (slideset in the right sidebar). Hello, Are you planning on adding some more animation effects to Themler? Thanks
Unfortunately we do not plan to add more animation effects in the near future.
Hi, Unfortunately we do not plan to add more animation effects in the near future. Thank you, Olivia
