spacing between content and footer
APC
APC posted this 20 March 2017
I have a spacing between content and footer. I try to use the Expand To Bottom extension but it doesn't work.
Could you help me please ?
Thanks.
Regards, Evelyne.
I have a spacing between content and footer. I try to use the Expand To Bottom extension but it doesn't work. Could you help me please ? Thanks. Regards, Evelyne.
Support Team posted this 21 March 2017
You need the content to be stretched to the footer? Then apply that extension to the Content and Sidebars control. If that does not help, provide your theme or access to the site back end.
Hi, You need the content to be stretched to the footer? Then apply that extension to the Content and Sidebars control. If that does not help, provide your theme or access to the site back end. Sincerely, Hella
APC
APC posted this 21 March 2017
Hi Hella,
Thanks for reply.
I've applied that extension to the Content and Sidebars control but it doesn't work... The blank space between content and footer is always here !
Frontend access :
http://dev.apc-info-services.fr
login : dev-apc
pass : dev-apc
Backend access :
http://dev.apc-info-services.fr/wp-admin
WP login : dev-apc
pass : dev-apc
Regards, Evelyne
Hi Hella, Thanks for reply. I've applied that extension to the Content and Sidebars control but it doesn't work... The blank space between content and footer is always here ! Frontend access : http://dev.apc-info-services.fr login : dev-apc pass : dev-apc Backend access : http://dev.apc-info-services.fr/wp-admin WP login : dev-apc pass : dev-apc Regards, Evelyne
Support Team posted this 22 March 2017
Sorry, I see the white gap only between the map and the block below. What gap you want to remove? Please provide a screen shot.
Hi, Sorry, I see the white gap only between the map and the block below. What gap you want to remove? Please provide a screen shot. Sincerely, Hella
APC
APC posted this 24 March 2017
I would like to suppress the gap between the black footer and and of the blue contant.
The gap is bigger on firefox than Chrome.
See attached files.
Regards, Evelyne.
Hi, I would like to suppress the gap between the black footer and and of the blue contant. The gap is bigger on firefox than Chrome. See attached files. Regards, Evelyne.
Support Team posted this 24 March 2017
Please add this code under the Home >> Settings >> Additional CSS:
.separated-item-25 {
    min-height: 200px!important;
Hi, Please add this code under the Home >> Settings >> Additional CSS: .separated-item-25 { min-height: 200px!important; } Sincerely, Hella
APC
Great !
The problem is solved now.
Thank you and have a nice day.
Regards, Evelyne.
Great ! The problem is solved now. Thank you and have a nice day. Regards, Evelyne.
