PHP Memory Configuration Error
lina3vt
lina3vt posted this 22 March 2017
Hi. I was working on a site on wordpress and when I tryed to open themler, I got this error message:
Themler requires at least 64Mb of PHP memory. Please increase your PHP memory to continue. For more information, please check this link.
I checked the link and made sure the memory limits in php and wp were 64M but I keept getting the error message and I can't work on my theme.
Please help me fix this issue.
Hi. I was working on a site on wordpress and when I tryed to open themler, I got this error message: PHP Memory Configuration Error Themler requires at least 64Mb of PHP memory. Please increase your PHP memory to continue. For more information, please check this link. I checked the link and made sure the memory limits in php and wp were 64M but I keept getting the error message and I can't work on my theme. Please help me fix this issue.
Support Team posted this 22 March 2017
Please check the following parameters in php.ini:
upload_max_filesize
memory_limit
post_max_size
Try to change them to 64M for testing.
It should help.
Hi, Please check the following parameters in php.ini: `upload_max_filesize` `memory_limit` `post_max_size` Try to change them to 64M for testing. It should help. Thank you, Olivia
buetow
buetow posted this 08 May 2017
Hello, I have the same Problem after updating the theme. I have increased the PHP settings and it still does not work no matter what I set in the php.ini
What can I do, thx for support
Wolfgang
Hello, I have the same Problem after updating the theme. I have increased the PHP settings and it still does not work no matter what I set in the php.ini What can I do, thx for support Wolfgang
buetow,
Please try the latest Beta update:
http://answers.themler.com/questions/53794/beta-testing
**buetow**, > I have the same Problem after updating the theme. Please try the latest Beta update: http://answers.themler.com/questions/53794/beta-testing Thank you, Olivia
