Custom URL for Menu Entries
info2976
info2976 posted this 28 March 2017
HTML5 Page.
I created a one page with smooth scrolling, and it works perfectly.
I created is a single page for (impressum or Disclaimer) with the a horizontal menu, but the links on this page back to home and the achors of the onepage didnĀ“t work because the links linking to #.... not to the homepageanchors.
The solution for me ist to edit the automatically generatet menu links on the single pages.
Sry for bad english.
HTML5 Page. I created a one page with smooth scrolling, and it works perfectly. I created is a single page for (impressum or Disclaimer) with the a horizontal menu, but the links on this page back to home and the achors of the onepage didn´t work because the links linking to #.... not to the homepageanchors. The solution for me ist to edit the automatically generatet menu links on the single pages. Sry for bad english.
Support Team posted this 28 March 2017
You mean that you have the home page with anchors and do have another page where the menu is the same and it does not go to the home page when clicked because there are anchors only? Consider using the full URL with anchor in the menu links.
Hi, You mean that you have the home page with anchors and do have another page where the menu is the same and it does not go to the home page when clicked because there are anchors only? Consider using the full URL with anchor in the menu links. Sincerely, Hella
info2976
Yes that`s correct, i tried to use the full URL, the links where working but the smooth scrolling does not work.
The best solution at the moment is to edit the links after export.
Yes that`s correct, i tried to use the full URL, the links where working but the smooth scrolling does not work. The best solution at the moment is to edit the links after export.
Support Team posted this 29 March 2017
in case there's a combination of links with and without anchors in your menu then the solution is to edit the links as you did. Or use absolute URLs in menu links.
Hello, in case there's a combination of links with and without anchors in your menu then the solution is to edit the links as you did. Or use absolute URLs in menu links. regards, Aileen
