2 Horizontal menu in Html5
duenzen
duenzen posted this 30 March 2017
Hi , I started to build a html5 Website .
But i need 2 seperate Horizontal Menu.
Is it possible to change the vertical to an horizontal menu.
Thanks for your support.
Hi , I started to build a html5 Website . But i need 2 seperate Horizontal Menu. Is it possible to change the vertical to an horizontal menu. Thanks for your support.
Support Team posted this 31 March 2017
You can try to play around with it/ Set the display option to inline for the vertical menu item, float option to left. Hope that it helps.
Hi, You can try to play around with it/ Set the display option to inline for the vertical menu item, float option to left. Hope that it helps. Sincerely, Hella
duenzen
duenzen posted this 31 March 2017
Thanks or your answer .
It´s not working with the vertical Menu.
I found a solution using the buttons to create a seperate menu.
But it would be nice to have a seperate horizontal menu in html5 for some reason.
Best regards
Volker
Thanks or your answer . It´s not working with the vertical Menu. I found a solution using the buttons to create a seperate menu. But it would be nice to have a seperate horizontal menu in html5 for some reason. Best regards Volker
OK, we'll consider your suggestion.
Hi, OK, we'll consider your suggestion. Sincerely, Hella
