SubMenu Settings
len
len posted this 13 April 2017
I want the submenus on the phone to be centered.
I have got the cheesburger icon centred and the top level centred, but the menu item for an active page is left aligned and the submenu left aligned.
On the desktop display, if I set the submenu direction to right, the submenu is under the main menu item. If I set the direction to left, the submenu is under the main menu item to the RIGHT of the main menu item.
Whats supposed to happen with these settings please, and how do I centre and change the width of the submenu item block?
LenW
I want the submenus on the phone to be centered. I have got the cheesburger icon centred and the top level centred, but the menu item for an active page is left aligned and the submenu left aligned. On the desktop display, if I set the submenu direction to right, the submenu is under the main menu item. If I set the direction to left, the submenu is under the main menu item to the RIGHT of the main menu item. Whats supposed to happen with these settings please, and how do I centre and change the width of the submenu item block? Thanks LenW
Support Team posted this 17 April 2017
Sorry for the delay.
Could you please attach the problem theme so we can check theme settings.
Hi, Sorry for the delay. Could you please attach the problem theme so we can check theme settings. Thank you, Olivia
