Static Footer Animation Design
Web IT Solutions LLP
Web IT Solutions LLP posted this 21 April 2017
Dear Sir,
1) Can you achieve the similar footer animation as from the following sample link,
https://www.wearefine.com/
Something like the static position of footer...
If yes, kindly let us know the steps using Themler.
Appreciate your support in advance, And, really thanks a lot for new updates & release...
2) Can you let us know is there any particular updates released yesterday on 20th April 2017 for HTML Projects. If yes, what are they? Because we are using most of the projects HTML only.
3) Hybrid menu with images etc. Is Themler supports this kind of design,
Sample Link - https://www.domainecarneros.com/
4) Horizontal Menu Animation Left or Right panel Opening? Instead of regular horizontal menu. ?
Suffian Ahmed
Dear Sir, 1) Can you achieve the similar footer animation as from the following sample link, https://www.wearefine.com/ Something like the static position of footer... If yes, kindly let us know the steps using Themler. Appreciate your support in advance, And, really thanks a lot for new updates & release... 2) Can you let us know is there any particular updates released yesterday on 20th April 2017 for HTML Projects. If yes, what are they? Because we are using most of the projects HTML only. 3) Hybrid menu with images etc. Is Themler supports this kind of design, Sample Link - https://www.domainecarneros.com/ 4) Horizontal Menu Animation Left or Right panel Opening? Instead of regular horizontal menu. ? Regards Suffian Ahmed
Support Team posted this 24 April 2017
1).do you mean a kind of fixed footer?
In this case you may:
1.create fixed footer following the screenshot
2.for the DIV tag which includes the min page content specify z-index lower than footer's z-index. It should be done via custom CSS.
2).all changes and fixes are listed in the release notes
http://answers.themler.com/questions/128105/themler-v-367-update-20-april-2017
If you're interested in a specific fix or change please provide more detailed descriptions.
3).Themler supports Mega Menu, but it does not allow to incorporate images like on example you provided.
4).you may create special Container controls and apply existing animations to Containers. Them locate menu(s) inside Container control.
Hello, 1).do you mean a kind of fixed footer? In this case you may: 1.create fixed footer following the screenshot !FixedFooter.png! 2.for the DIV tag which includes the min page content specify z-index lower than footer's z-index. It should be done via custom CSS. 2).all changes and fixes are listed in the release notes http://answers.themler.com/questions/128105/themler-v-367-update-20-april-2017 If you're interested in a specific fix or change please provide more detailed descriptions. 3).Themler supports Mega Menu, but it does not allow to incorporate images like on example you provided. 4).you may create special Container controls and apply existing animations to Containers. Them locate menu(s) inside Container control. regards, Aileen
Web IT Solutions LLP posted this 24 April 2017
Dear Mr. Aileen,
Joomla, Virtual Mart, WordPress, WooCommerce etc but I believe there is no HTML Project section fixes or updates releases notes in the above link. I think there is not HTML Fixes or updates?
1) And, could you let us know how to add custom installed local fonts of my system into Themler. ?
2) The export themler project changing the text as below
    <!-- Start WOWSlider.com HEAD section -->
<link rel="stylesheet" type="text/css" href="engine4/style.css" />
<script type="text/javascript" src="engine4/jquery.js"></script>
<!-- End WOWSlider.com HEAD section -->
into
<link rel="stylesheet" type="text/css" href="engine4/style.min.css" />
The text -> href="engine4/style.css" is renaming with href="engine4/style.min.css" in export HTML Project... Why ? Every time i need to change the text back by removing "min.css" from the .html files using html editor. Why ?
3) Can we get more slider animation, please ? Please check the http://wowslider.com/ expecting more as this.
Suffian Ahmed
Dear Mr. Aileen, 2).all changes and fixes are listed in the release notes http://answers.themler.com/questions/128105/themler-v-367-update-20-april-2017 If you're interested in a specific fix or change please provide more detailed descriptions. Joomla, Virtual Mart, WordPress, WooCommerce etc but I believe there is no HTML Project section fixes or updates releases notes in the above link. I think there is not HTML Fixes or updates? 1) And, could you let us know how to add custom installed local fonts of my system into Themler. ? 2) The export themler project changing the text as below <!-- Start WOWSlider.com HEAD section --> <link rel="stylesheet" type="text/css" href="engine4/style.css" /> <script type="text/javascript" src="engine4/jquery.js"></script> <!-- End WOWSlider.com HEAD section --> into <!-- Start WOWSlider.com HEAD section --> <link rel="stylesheet" type="text/css" href="engine4/style.min.css" /> <script type="text/javascript" src="engine4/jquery.js"></script> <!-- End WOWSlider.com HEAD section --> The text -> `href="engine4/style.css"` is renaming with `href="engine4/style.min.css"` in export HTML Project... Why ? Every time i need to change the text back by removing "min.css" from the .html files using html editor. Why ? 3) Can we get more slider animation, please ? Please check the http://wowslider.com/ expecting more as this. Regards Suffian Ahmed
Support Team posted this 26 April 2017
1.there're no major updates to bug fixes for HTML. If you're interested in specific issue, please let us know it and we'll check the status.
1).this post describes how to load custom fonts in Themler.
2).I cannot reproduce this issue. Could you please attach here the theme which demonstrates it?
3).right now the new options and features are put on hold in Themler. However I've added your request to our wish list for the future. Thank you.
Hello, 1.there're no major updates to bug fixes for HTML. If you're interested in specific issue, please let us know it and we'll check the status. 1).this post describes how to load custom fonts in Themler. 2).I cannot reproduce this issue. Could you please attach here the theme which demonstrates it? 3).right now the new options and features are put on hold in Themler. However I've added your request to our wish list for the future. Thank you. regards, Aileen
Web IT Solutions LLP posted this 26 April 2017
Hi Aileen,
Which post, seems the link is missing.
Suffian Ahmed
Hi Aileen, 1).this post describes how to load custom fonts in Themler. Which post, seems the link is missing. Regards Suffian Ahmed
Support Team posted this 27 April 2017
I'm sorry for the inconvenience, here is the link
http://answers.themler.com/questions/3368/add-custom-fonts
Hello, I'm sorry for the inconvenience, here is the link http://answers.themler.com/questions/3368/add-custom-fonts Regards, Aileen
