Request failed: 500 when trying to import content from template.
gary
gary posted this 28 April 2017
Hi I get a "Request failed: 500" error when I try to import content from a template created using themler. Any help would be appreciated.
GAry
Hi I get a "Request failed: 500" error when I try to import content from a template created using themler. Any help would be appreciated. GAry
12 Comments
Support Team posted this 28 April 2017
Please try the following suggestions:
https://answers.themler.com/articles/65488/troubleshooting-read-first
That may be issue with the permissions.
Hi, Please try the following suggestions: https://answers.themler.com/articles/65488/troubleshooting-read-first That may be issue with the permissions. Sincerely, Hella
james106
james106 posted this 03 July 2017
Getting the same problem. I completed this on previous theme prior to upgrading to latest php version. I've not changed any permissions
Support Team posted this 14 July 2017
Sorry for the delay. Try to check the permissions once again as something might have changed after updating the PHP. Also try to disable plug-ins on the site.
Hi, Sorry for the delay. Try to check the permissions once again as something might have changed after updating the PHP. Also try to disable plug-ins on the site. Sincerely, Hella
giancarlo
giancarlo posted this 30 September 2017
I'm experiencing this problem on a fresh joomla 3.8 installation. No plugin installed by my own, File and folder permissions are OK. No htpps, no htacces entry.
The theme has been correctly uploaded and working if selected, but it can't be managed:
Install Content Plugins : request failed 500
import content from template: request failed 500
Edit Template: not possible server error...
Any help would be great!
Thanks for your attention.
Giancarlo.
I'm experiencing this problem on a fresh joomla 3.8 installation. No plugin installed by my own, File and folder permissions are OK. No htpps, no htacces entry. The theme has been correctly uploaded and working if selected, but it can't be managed: Install Content Plugins : request failed 500 import content from template: request failed 500 Edit Template: not possible server error... Any help would be great! Thanks for your attention. Giancarlo.
Support Team posted this 30 September 2017
Hello Giancarlo,
Could you please create a new private topic and provide temporary access to your website for investigation?
Hello Giancarlo, Could you please create a new private topic and provide temporary access to your website for investigation? Sincerely, Nettie, BillionDigital Team
udacha700
udacha700 posted this 23 January 2018
The problem was solved by a change in the local CMS, which works with the Temler editor,
the menu heading
Content / Content / Content / Content
on
Content
As he acquired this form - I do not know, probably after a few improms of various content.
The problem was solved by a change in the local CMS, which works with the Temler editor, the menu heading Content / Content / Content / Content on Content As he acquired this form - I do not know, probably after a few improms of various content.
raffe
raffe posted this 29 January 2018
I have the same problem
In Joomla menu - Templates: Edit style: "Themler import content from template" - Request failed: 404
Where exactly can I fix this problem?
Hello, I have the same problem In Joomla menu - Templates: Edit style: "Themler import content from template" - Request failed: 404 Where exactly can I fix this problem? Thanks
Support Team posted this 29 January 2018
raffe,
Looks like the issue is different in your case. Could you please try creating a new private topic and provide temporary access to your website admin panel?
**raffe**, Looks like the issue is different in your case. Could you please try creating a new private topic and provide temporary access to your website admin panel? Sincerely, Nettie, BillionDigital Team
james93
james93 posted this 07 December 2018
I am having same issues with fresh install joomla 3.9.1. When I try install content plugings I get Request failed: 500
Please Advise?
I am having same issues with fresh install joomla 3.9.1. When I try install content plugings I get Request failed: 500 Please Advise?
Giuma
Giuma posted this 08 December 2018
for error 500, you must reapir folder and files default pesmision in your server
james93
james93 posted this 08 December 2018
I have done that using latest admin tools, still no joy. Error 500 persists.
> for error 500, you must reapir folder and files default pesmision in your server > I have done that using latest admin tools, still no joy. Error 500 persists.
Support Team posted this 11 December 2018
Hi James,
Sorry for the delay in response.
I would recommend you to create a new private support ticket and provide us with all necessary information there so that we can try to help you.
Ivan
Hi James, Sorry for the delay in response. I would recommend you to create a new private support ticket and provide us with all necessary information there so that we can try to help you. Thanks, Ivan
