Probem php memory
frederic11
frederic11 posted this 29 April 2017
i have a problem, i have just upgrade to Joomla 3.7, and i havent check before is there was an update of Themler.
No, i have a php memory limit error when try to open Themler. But the memory is good on my server and never have this problem before.
Thanks for help.
Hello, i have a problem, i have just upgrade to Joomla 3.7, and i havent check before is there was an update of Themler. No, i have a php memory limit error when try to open Themler. But the memory is good on my server and never have this problem before. Thanks for help.
30 Comments
frederic11
Re hello, it is a big problem, because i have this problem now for all my site upgraded in Joomla 3.7.
I have tested with the latest version of Themler it is the same problem. I can't access anymore of all my Themler template on my site.
Help please.
Re hello, it is a big problem, because i have this problem now for all my site upgraded in Joomla 3.7. I have tested with the latest version of Themler it is the same problem. I can't access anymore of all my Themler template on my site. Help please. Regards !Templates---Modifier-le-style---www-OpenActe-ch---Administration.jpg! !php.jpg!
pegu
pegu posted this 29 April 2017
I have a same problem.
There is some solution? Ist Bug?
Thanks.
I have a same problem. There is some solution? Ist Bug? Thanks.
Support Team posted this 29 April 2017
We are sorry for the issue. The fix will be included into the hotfix update in the near future.
Hello, We are sorry for the issue. The fix will be included into the hotfix update in the near future. Sincerely, Nettie, BillionDigital Team
frederic11
Hello, yes, but how we can update the theme if we cannot access to it ?
frederic11
Is there a way to modify a file manually by ftp to solve the problem, even temporary ?
Hi Frederic,
When the update is available, you may update the theme backup (the backup is created by each Themler update). As a temporary solution you may also edit this theme.
Hi Frederic, When the update is available, you may update the theme backup (the backup is created by each Themler update). As a temporary solution you may also edit this theme. Sincerely, Nettie, BillionDigital Team
frederic11
Hello, OK, it work if i use the backup in the joomla template admin.
I wait for your back for the new update.
Hello, OK, it work if i use the backup in the joomla template admin. I wait for your back for the new update. Regards
Ok, we will try updating Themler as soon as possible. Thank you for your patience.
Hello, Ok, we will try updating Themler as soon as possible. Thank you for your patience. Sincerely, Nettie, BillionDigital Team
Vitaliy WD
Vitaliy WD posted this 30 April 2017
BTW I tested last version of Themler on PHP 7.1 (instead 7.0) and seems that it's work faster and stable on PHP 7.1. Just feelengs... if someone can also compare PHP 7.0 / 7.1 with last Themler - write your report.
frederic11
frederic11 posted this 30 April 2017
Same problem for me with php 7.1
frederic11
Me again,
i just tested the latest version of Themler on a Joomla 3.6.5. Same problem.
So it is not the 3.7 version of Joomla the problem but the Themler version.
Me again, i just tested the latest version of Themler on a Joomla 3.6.5. Same problem. So it is not the 3.7 version of Joomla the problem but the Themler version. Regards
Support Team posted this 02 May 2017
The fix for the issue will be available soon - please make sure to enable Beta updates in your profile, as this update will appear as Beta first.
Hello, The fix for the issue will be available soon - please make sure to enable Beta updates in your profile, as this update will appear as Beta first. Sincerely, Nettie, BillionDigital Team
The update with the fix included is ready, please try updating to the latest Beta version. You may need to check the box next to "Get Beta updates" in your profile to receive the Beta update notification. After installing the Beta update you may uncheck the box at an time.
Hello, The update with the fix included is ready, please try updating to the latest Beta version. You may need to check the box next to "Get Beta updates" in your profile to receive the Beta update notification. After installing the Beta update you may uncheck the box at an time. Sincerely, Nettie, BillionDigital Team
pegu
pegu posted this 02 May 2017
after beta update is OK... Thanks
You are welcome!
You are welcome! Sincerely, Nettie, BillionDigital Team
frederic11
frederic11 posted this 02 May 2017
Yes, OK with Beta.
Yes, OK with Beta. Regards
Hi Fredetic,
Thanks for letting us know!
Hi Fredetic, Thanks for letting us know! Sincerely, Nettie, BillionDigital Team
marcin_tomas
marcin_tomas posted this 07 May 2017
I have another problem.
I made beta update and it solved problem with php.
But now, when I try download template (export), this file is considered rare, when I ignore this, download don't work.
Google includes the content page of the nature of social engineering, on my other page. As an example, this is the path to themler. The site is not infected, I checked it. It is only in the creation phase. The problem started with php error..
I have another problem. I made beta update and it solved problem with php. But now, when I try download template (export), this file is considered rare, when I ignore this, download don't work. Google includes the content page of the nature of social engineering, on my other page. As an example, this is the path to themler. The site is not infected, I checked it. It is only in the creation phase. The problem started with php error..
Vitaliy WD
Vitaliy WD posted this 07 May 2017
I confirm problem with Export: zip archive size 4kb and it's broken.
on my other page.
You can try to ask support for .htaccess rules that hide part of Themler's directories.
I confirm problem with Export: zip archive size 4kb and it's broken. > Google includes the content page of the nature of social engineering, > on my other page. You can try to ask support for .htaccess rules that hide part of Themler's directories.
Support Team posted this 11 May 2017
marcin_tomas,
The issue does not happen on our end. Possibly there are some third-party plugins or components that are related to the issue - could you please try temporarily disabling them and let us know if this makes any difference?
Vitaliy WD,
The issue with export on Joomla was fixed in the Beta update of yesterday, please try it and let us know if the issue persists.
**marcin_tomas**, The issue does not happen on our end. Possibly there are some third-party plugins or components that are related to the issue - could you please try temporarily disabling them and let us know if this makes any difference? **Vitaliy WD**, The issue with export on Joomla was fixed in the Beta update of yesterday, please try it and let us know if the issue persists. Sincerely, Nettie, BillionDigital Team
