JFRAMEWORK_FORM_FIELDS_PLUGINS_ERROR_FOLDER_EMPTY
einkauf4
einkauf4 posted this 30 April 2017
After exporting a zip file of template in joomla backend and upload to any other site, the template can not be edited in new site.
Always error: JFRAMEWORK_FORM_FIELDS_PLUGINS_ERROR_FOLDER_EMPTY ..
Find more and more bugs and no solutions.. Themler seems to become more and more useless??
After exporting a zip file of template in joomla backend and upload to any other site, the template can not be edited in new site. Always error: JFRAMEWORK_FORM_FIELDS_PLUGINS_ERROR_FOLDER_EMPTY .. Find more and more bugs and no solutions.. Themler seems to become more and more useless??
einkauf4
.... and please do not ask again for backend access as you never checked in other tickets...
You should know the errors.. Paid for themler but it gets more and more down on all sites and does not work..
Absolutely can not use it anymore and lose all our templates !!!
.... and please do not ask again for backend access as you never checked in other tickets... You should know the errors.. Paid for themler but it gets more and more down on all sites and does not work.. Absolutely can not use it anymore and lose all our templates !!!
Support Team posted this 03 May 2017
Did you update this theme to the latest version? If so please check the size of the exported ZIP. If it is about 3Kb then we know what the problem it is and it should be fixed in the future Themler updates.
In the meantime you can download the theme by FTP or use theme backup created before update.
Hi, Did you update this theme to the latest version? If so please check the size of the exported ZIP. If it is about 3Kb then we know what the problem it is and it should be fixed in the future Themler updates. In the meantime you can download the theme by FTP or use theme backup created before update. Thank you, Olivia
informatyk3
informatyk3 posted this 05 September 2017
Hello.
After updating Joomal a warning appeared: JFRAMEWORK_FORM_FIELDS_PLUGINS_ERROR_FOLDER_EMPTY
I have not been able to edit the template in the Themler plug-in, which has worked well and correctly.
Attach a dump from the template section.
enter image description here
Hello. After updating Joomal a warning appeared: JFRAMEWORK_FORM_FIELDS_PLUGINS_ERROR_FOLDER_EMPTY I have not been able to edit the template in the Themler plug-in, which has worked well and correctly. Attach a dump from the template section. ![enter image description here][1] [1]: http://test.gminasepolno.beep.pl/joomla_desing_themler.jpg
Support Team posted this 05 September 2017
Please create a new private ticket and provide us with a temp access to your Joomla back-end there so we can try to help you.
Ivan
Hi, Please create a new private ticket and provide us with a temp access to your Joomla back-end there so we can try to help you. Thanks, Ivan
Werbeagentur Schulz-Design
Werbeagentur Schulz-Design posted this 06 March 2019
I have the same problem.
I need a second template and wanted to export the finished template under a different name than zip. The file size is 8 MB. After installing the template this error message appears and I can not edit it.
Thorsten
http://www.schulzdesign.info
Hello, I have the same problem. I need a second template and wanted to export the finished template under a different name than zip. The file size is 8 MB. After installing the template this error message appears and I can not edit it. Sincerely, Thorsten http://www.schulzdesign.info
