Wordpress Customizer
Stagger Lee posted this 03 June 2015
Do you plan to make it work ?
As it is now Themler complains theme is not activated.
Wordpress bets a lot in last year in Customizer. And they do great work on it.
This is message.
Please activate theme and use link "Customize" for designing the template.
Do you plan to make it work ? As it is now Themler complains theme is not activated. Wordpress bets a lot in last year in Customizer. And they do great work on it. This is message. **Please activate theme and use link "Customize" for designing the template.**
10 Comments
Support Team posted this 03 June 2015
The Appearance >> Customize options is available for themes which were installed without Themler.
We have not yet decided what to do with this options when the theme is installed with Themler. The problem is that there is one more Customize option under the Appearance >> Themes. This option loads Themler. So, in general the Appearance >> Customize option should load Themler too to avoid confusion.
Hello The **Appearance** >> **Customize** options is available for themes which were installed without Themler. We have not yet decided what to do with this options when the theme is installed with Themler. The problem is that there is one more **Customize** option under the **Appearance** >> **Themes**. This option loads Themler. So, in general the **Appearance** >> **Customize** option should load Themler too to avoid confusion. Thank you, Olivia
I tested now, works without Themler code part when exporting Theme.
So it is good for now.
Fast it would be nice to have this WP native options even ehen Themler is activated in Theme.
And if you can remove main menu item to Billion Theme in backend. People are not stupid, they can find it under Appearance.
I tested now, works without Themler code part when exporting Theme. So it is good for now. Fast it would be nice to have this WP native options even ehen Themler is activated in Theme. And if you can remove main menu item to Billion Theme in backend. People are not stupid, they can find it under Appearance.
Support Team posted this 04 June 2015
Hello Stagger Lee,
there's the suggestion in our wish list to optionally hide the BillionThemler menu in WP admin back end. However now we're working on other tasks, I cannot say when it will be implemented.
Hello Stagger Lee, there's the suggestion in our wish list to optionally hide the BillionThemler menu in WP admin back end. However now we're working on other tasks, I cannot say when it will be implemented. Regards, Aileen
Stagger Lee posted this 04 June 2015
It is OK, dont worry, when you have time. Those who are lazy to use search option here in forum dont deserve any help.
Linkebel
Linkebel posted this 04 June 2015
+1 to hide the option themler in the menu
-1 For customizing the theme whit wordpress, I don't want my clients to do this without going through me, because in the future they will change the themes themselves and would i have less working
+1 to hide the option themler in the menu -1 For customizing the theme whit wordpress, I don't want my clients to do this without going through me, because in the future they will change the themes themselves and would i have less working
lavisbre
lavisbre posted this 12 March 2016
not following your solutions?
i made a site in themlar
i zipped the site and uploaded it to my server with ipage.
i also loaded it to wordpress so i could activate it.
all that opened was my header and logo, yes thats right all my home page was missing ecept the header.
this site also wont activate and gives error message saying please active to customize???
So for those who are not "coders" can you please explain why i can use templates from other places but not ones made in themlar. the reason i brought this program was to make a site myself which is cool in themlar.... however useless waste of time as it wont transfer to wordpress.
so to conclude.
themlar woocommerce dont work in wordpress, please tell me why or fix the bug please.
not following your solutions? i made a site in themlar i zipped the site and uploaded it to my server with ipage. i also loaded it to wordpress so i could activate it. all that opened was my header and logo, yes thats right all my home page was missing ecept the header. this site also wont activate and gives error message saying please active to customize??? So for those who are not "coders" can you please explain why i can use templates from other places but not ones made in themlar. the reason i brought this program was to make a site myself which is cool in themlar.... however useless waste of time as it wont transfer to wordpress. so to conclude. themlar woocommerce dont work in wordpress, please tell me why or fix the bug please.
Support Team posted this 14 March 2016
I assume that you have exported the theme and after installation expected the content to appear as well. But Themler does not export content, it can only edit it. So the proper way is to install the theme on the live site and then edit the content using the WP or Themler editor.
In case you have any other issues or questions regarding this point, please create a separate ticket with the link to your site, theme attached and some screen shots demonstrating the issue.
Hi, I assume that you have exported the theme and after installation expected the content to appear as well. But Themler does not export content, it can only edit it. So the proper way is to install the theme on the live site and then edit the content using the WP or Themler editor. In case you have any other issues or questions regarding this point, please create a separate ticket with the link to your site, theme attached and some screen shots demonstrating the issue. Sincerely, Hella
scott53
scott53 posted this 19 October 2016
I'm having this same issue and its months after the initial post. I installed the woocommerce plug in so I can change the text and button colors in the products. I DID have this same error before installing this plug in but now its an issue for me. I can't edit anything in WP.
Thank you for any help. This is becoming very frustrating since I actually was dumb enough to pay for this software to make things easier the coding html.
Hello, I'm having this same issue and its months after the initial post. I installed the woocommerce plug in so I can change the text and button colors in the products. I DID have this same error before installing this plug in but now its an issue for me. I can't edit anything in WP. **Please activate theme and use link "Customize" for designing the template.** Thank you for any help. This is becoming very frustrating since I actually was dumb enough to pay for this software to make things easier the coding html.
Stagger Lee posted this 19 October 2016
Forum is shuffling comments (per one thread) in last days. Follow not dates. OK, sorry. It remembers my old order setitng.
Support Team posted this 20 October 2016
Customizer does not work with Themler themes. To edit the theme you need to activate it and use the Themler tab in the WP back end:
http://answers.themler.com/articles/3626/how-to-use-wordpress-theme
Hi, Customizer does not work with Themler themes. To edit the theme you need to activate it and use the Themler tab in the WP back end: http://answers.themler.com/articles/3626/how-to-use-wordpress-theme Sincerely, Hella
