Woocommerce sku product variations
Jorge
Jorge posted this 04 May 2017
I am trying to see the sku of the products, but when they are variables it does not show them.
In the product variations control, if sku variable is displayed.
I am using this code in a cms code:
<p><span>
    <?php if ( $product->is_type( array( 'simple', 'variable' ) ) && get_option('woocommerce_enable_sku') == 'yes' && $product->get_sku() ) : ?>
        <span itemprop="productID" class="sku"><?php _e('','qns' ); ?> <?php echo $product->get_sku(); ?>.</span>
    <?php endif; ?>- <?php  echo $product->get_title(); ?>
  </span> </p>
You can help me, thank you.
Hi I am trying to see the sku of the products, but when they are variables it does not show them. In the product variations control, if sku variable is displayed. I am using this code in a cms code: <p><span> <?php if ( $product->is_type( array( 'simple', 'variable' ) ) && get_option('woocommerce_enable_sku') == 'yes' && $product->get_sku() ) : ?> <span itemprop="productID" class="sku"><?php _e('','qns' ); ?> <?php echo $product->get_sku(); ?>.</span> <?php endif; ?>- <?php echo $product->get_title(); ?> </span> </p> You can help me, thank you.
8 Comments
Support Team posted this 05 May 2017
I've tested the provided code on my side with the blank Themler theme (T-Shirt product) and the SKU is visible.
Did you test this code on your side with non-Themler theme? Does it work?
Hi, I've tested the provided code on my side with the blank Themler theme (T-Shirt product) and the SKU is visible. Did you test this code on your side with non-Themler theme? Does it work? Thank you, Olivia
Jorge
Jorge posted this 05 May 2017
Hi Olivia,
The code was only tested on a themler template.
The sku is shown if it does not have variations, if there are variations in the product the sku goes blank.
Can you use the product variations control code, and only show the sku?
Hi Olivia, The code was only tested on a themler template. The sku is shown if it does not have variations, if there are variations in the product the sku goes blank. Can you use the product variations control code, and only show the sku? Thank you
I have a product with variations and SKU is displayed:
Please show us the settings of your product and try this code with the default WP theme.
Hi, I have a product with variations and SKU is displayed: !woo-prod-sku.png! Please show us the settings of your product and try this code with the default WP theme. Thank you, Olivia
Jorge
I think I have not explained myself correctly, I'm sorry.
The original sku of the product if you show it, it is true. But if the variation has a sku of its own, this is not shown in the code I have used.
But in the control of product variations (Sku, categories, etc), the sku of the variation if shown.
enter image description here
Hello, I think I have not explained myself correctly, I'm sorry. The original sku of the product if you show it, it is true. But if the variation has a sku of its own, this is not shown in the code I have used. But in the control of product variations (Sku, categories, etc), the sku of the variation if shown. Thank you ![enter image description here][1] [1]: https://preview.ibb.co/fgmHWQ/variations.jpg
Jorge
Jorge posted this 09 May 2017
Hi, any idea?
Hi, any idea? Thanks
Jorge
Is Solution
Hi, this code work properly :)
   <?php
global $product;
<div class>
    <?php do_action( 'woocommerce_product_meta_start' ); ?>
    <?php if ( wc_product_sku_enabled() && ( $product->get_sku() || $product->is_type( 'variable' ) ) ) : ?>
        <span class="sku_wrapper"><?php esc_html_e( '', 'woocommerce' ); ?> <span class="sku"><?php echo ( $sku = $product->get_sku() ) ? $sku : esc_html__( 'N/A', 'woocommerce' ); ?></span></span>
  <?php endif;?><span> <?php the_title();?></span>
  <?php do_action( 'woocommerce_product_meta_end' );?>
Hi, this code work properly :) <?php global $product; ?> <div class> <?php do_action( 'woocommerce_product_meta_start' ); ?> <?php if ( wc_product_sku_enabled() && ( $product->get_sku() || $product->is_type( 'variable' ) ) ) : ?> <span class="sku_wrapper"><?php esc_html_e( '', 'woocommerce' ); ?> <span class="sku"><?php echo ( $sku = $product->get_sku() ) ? $sku : esc_html__( 'N/A', 'woocommerce' ); ?></span></span> <?php endif;?><span> <?php the_title();?></span> <?php do_action( 'woocommerce_product_meta_end' );?> Thanks :)
andre.pedro
andre.pedro posted this 10 July 2017
I was searching for this feature!
In which file I must paste this code?
Thanks!
Hello, I was searching for this feature! In which file I must paste this code? Thanks!
Jorge
Jorge posted this 10 July 2017
Thanks!
Hi!
Put the Code in a cms box
> Hello, > > I was searching for this feature! > > In which file I must paste this code? > > Thanks! Hi! Put the Code in a cms box Regards
