Joomla 3.7 compatible with Artisteer and Themler?
tarj1974
tarj1974 posted this 05 May 2017
Is Joomla! 3.7 compatible with both Artisteer and Themler in recent versions?
Best Regards,
Thomas :)
Is Joomla! 3.7 compatible with both Artisteer and Themler in recent versions? Best Regards, Thomas :)
9 Comments
In general yes, Themler and Artisteer themes should work ok without major issues on Joomla 3.7.
If you encounter any problems please let us know.
Hi, In general yes, Themler and Artisteer themes should work ok without major issues on Joomla 3.7. If you encounter any problems please let us know. Thank you, Olivia
pschlappy
pschlappy posted this 08 May 2017
After updating to Joomla 3.7.0 the function Import Content from Template is gone.
Can you help me to fix this?
After updating to Joomla 3.7.0 the function Import Content from Template is gone. Can you help me to fix this?
pdg.design
pdg.design posted this 09 May 2017
Artisteer templates in Joomla have error with PHP 7.1
Support Team posted this 10 May 2017
Do you mean that this option is missing on your side?
This option is not visible if you exported theme without content.
I'll ask Artisteer theme to check this issue.
Hi, > After updating to Joomla 3.7.0 the function Import Content from Template is gone. Do you mean that this option is missing on your side? This option is not visible if you exported theme without content. > Artisteer templates in Joomla have error with PHP 7.1 I'll ask Artisteer theme to check this issue. Thank you, Olivia
tarj1974
tarj1974 posted this 14 May 2017
But > Hi,
What about Themler and PHP 7.x compatibility problems?
Best Regards,
Thomas
> Hi, > > In general yes, Themler and Artisteer themes should work ok without major issues on Joomla 3.7. > If you encounter any problems please let us know. > > Thank you, > Olivia But > Hi, > > > After updating to Joomla 3.7.0 the function Import Content from Template is gone. > > Do you mean that this option is missing on your side? > This option is not visible if you exported theme without content. > > > Artisteer templates in Joomla have error with PHP 7.1 > > I'll ask Artisteer theme to check this issue. > > Thank you, > Olivia > What about Themler and PHP 7.x compatibility problems? Best Regards, Thomas
tarj1974
But > Hi,
What about Themler and PHP 7.x compatibility problems? As you may know I'm having problems with showing the imported content, and showing my menus
Best Regards,
Thomas
> > Hi, > > > > In general yes, Themler and Artisteer themes should work ok without major issues on Joomla 3.7. > > If you encounter any problems please let us know. > > > > Thank you, > > Olivia > > But > Hi, > > > > > After updating to Joomla 3.7.0 the function Import Content from Template is gone. > > > > Do you mean that this option is missing on your side? > > This option is not visible if you exported theme without content. > > > > > Artisteer templates in Joomla have error with PHP 7.1 > > > > I'll ask Artisteer theme to check this issue. > > > > Thank you, > > Olivia > > > What about Themler and PHP 7.x compatibility problems? As you may know I'm having problems with showing the imported content, and showing my menus Best Regards, Thomas
Support Team posted this 16 May 2017
tarj1974,
We've solved PHP 7.1 compatibility issues in the last Themler public update.
We'll check reported issues with menus and content in the appropriate topics.
**tarj1974**, We've solved PHP 7.1 compatibility issues in the last Themler public update. We'll check reported issues with menus and content in the appropriate topics. Thank you, Olivia
Kommas.nl
Kommas.nl posted this 17 May 2017
Where can we find this update Olivia?
Support Team posted this 17 May 2017
As usual, when update is available you should see the following icon:
The PHP 7.1 compatibility problems were fixed in the latest publick 364 update.
Hi, As usual, when update is available you should see the following icon: !update-themler.png! The PHP 7.1 compatibility problems were fixed in the latest publick 364 update. Thank you, Olivia
