PHP Error
marcin_tomas
marcin_tomas posted this 07 May 2017
When I try enter to my template, message appears:
PHP Memory Configuration Error
Themler requires at least 64Mb of PHP memory(you have 128). Please increase your PHP memory to continue. For more information, please check this link.
I was able to access the template through copies from the update, but I can't download template. The file is only 4KB.
The problem has already appeared on two of my pages
When I try enter to my template, message appears: PHP Memory Configuration Error Themler requires at least 64Mb of PHP memory(you have 128). Please increase your PHP memory to continue. For more information, please check this link. I was able to access the template through copies from the update, but I can't download template. The file is only 4KB. The problem has already appeared on two of my pages
Vitaliy WD
Vitaliy WD posted this 07 May 2017
Seems that this issue was solved in current beta release, so you can try to update theme to the last beta (check Get Beta Updates in your Profile).
More info here: http://answers.themler.com/questions/129486/probem-php-memory
Seems that this issue was solved in current beta release, so you can try to update theme to the last beta (check **Get Beta Updates** in your **Profile**). More info here: http://answers.themler.com/questions/129486/probem-php-memory
The issue with exporting should be fixed in the next Beta update this week.
In the meantime please download the theme manually by FTP.
Hi, The issue with exporting should be fixed in the next Beta update this week. In the meantime please download the theme manually by FTP. Thank you, Olivia
marcin_tomas
marcin_tomas posted this 08 May 2017
OK but what with blacklisted from Google??
Support Team posted this 10 May 2017
Please describe the issue in more details or provide a link to the initial topic.
Hi, > OK but what with blacklisted from Google?? Please describe the issue in more details or provide a link to the initial topic. Thank you, Olivia
