Big disappointment
martin100660
martin100660 posted this 08 May 2017
I just made a subscription for Themler but I'm very disappointed.
It seems Themler is living an own life on my Mac.
When I export I can not find the zip file anywhere. There is also no dialogue screen to choose a location. Where is this zip file when you make an export from the local Themler program on a Mac?
I have no idea how to use the template in Joomla. Also here it seems Themler is going her own way by bypassing the normal way of working with positions in Joomla. I have absolutely no idea how work with this program.
Martin
I just made a subscription for Themler but I'm very disappointed. It seems Themler is living an own life on my Mac. When I export I can not find the zip file anywhere. There is also no dialogue screen to choose a location. Where is this zip file when you make an export from the local Themler program on a Mac? I have no idea how to use the template in Joomla. Also here it seems Themler is going her own way by bypassing the normal way of working with positions in Joomla. I have absolutely no idea how work with this program. Regards Martin
Support Team posted this 11 May 2017
Themler uses browser (Safari on Mac) and its default location for downloads.
Themler exports regular joomla templates. Could you please explain your problems with Themler themes on joomla in more details?
Themler theme has a control called "joomla position" which creates regular joomla module position in the place where you added it. The control is available under the Insert tab.
Hi, Themler uses browser (Safari on Mac) and its default location for downloads. > I have no idea how to use the template in Joomla. Themler exports regular joomla templates. Could you please explain your problems with Themler themes on joomla in more details? > Also here it seems Themler is going her own way by bypassing the normal way of working with positions in Joomla. I have absolutely no idea how work with this program. Themler theme has a control called "joomla position" which creates regular joomla module position in the place where you added it. The control is available under the Insert tab. Please keep us posted about the progress. Thank you, Olivia
