Customizing of theme is not allowed?
tech51
tech51 posted this 10 May 2017
Why my customer cannot Customizing there own theme this option should be allow to all the theme, they should be able to edit that footer,contest etc.
9 Comments
Support Team posted this 11 May 2017
Themler theme can be edited in the Themler editor only. To be able to save changes in the Themler editor your customer should have the Themler subscription.
Hi, Themler theme can be edited in the Themler editor only. To be able to save changes in the Themler editor your customer should have the Themler subscription. Sincerely, Hella
tech51
tech51 posted this 11 May 2017
I don't think this is right since I'm a web developer and my customer pay us to do there website they don't need to subscribe and what you are doing is forcing are customer to subscribe to your website
Vitaliy WD
Vitaliy WD posted this 11 May 2017
Actually for content management there is several CMS that Themler support. So you can use CMS for content editing by creating modules (Joomla) or widgets (wp) positions in Themler and put content inside it. Or create articles / posts inside CMS.
In this way you can use Themler just like a GUI for Bootstrap framework.
> I don't think this is right since I'm a web developer and my customer pay us to do there website they don't need to subscribe and what you are doing is forcing are customer to subscribe to your website Actually for content management there is several CMS that Themler support. So you can use CMS for content editing by creating modules (Joomla) or widgets (wp) positions in Themler and put content inside it. Or create articles / posts inside CMS. In this way you can use Themler just like a GUI for Bootstrap framework.
tech51
We pay for a subscription but not to have restriction.....If my customer need to change the footer phone number, address,email, logo, they should be able to do anything in there website..
Support Team posted this 12 May 2017
To allow the customer to edit the listed elements you should use Widget Area controls with widgets instead of fixed text in Themler. The Logo can be changed under the Appearance >> Theme Options in case you're using logo control.
Hi, > .If my customer need to change the footer phone number, address,email, logo, they should be able to do anything in there website.. To allow the customer to edit the listed elements you should use Widget Area controls with widgets instead of fixed text in Themler. The Logo can be changed under the Appearance >> Theme Options in case you're using logo control. Thank you, Olivia
tech51
tech51 posted this 12 May 2017
You are not answering my question ..My customer need to change the footer phone number, address,email, logo, they should be able to do this at anything in there website..there should not be restricted by you or by anyone.
Went they go to do any change they get this.. Because you are forcing are customer to subscribe to your website
You are not answering my question ..My customer need to change the footer phone number, address,email, logo, they should be able to do this at anything in there website..there should not be restricted by you or by anyone. Went they go to do any change they get this.. Because you are forcing are customer to subscribe to your website ** Customizing of theme is not allowed **
In order to not force the customer to purchase Themelr for editing static theme element you should use dynamic WP content instead. The widget areas with text widgets instead of the static text (footer phone number or any other text). Please understand the difference between static design elements and WP content. For any thing that you want to be changed through the WP admin panel please use WP tools (widgets and posts/pages). The Text control that you're using for phone number is the same design element as button color, for example. Simply use controls with dynamic content like widgets.
The "Customizing of theme is not allowed" message appears when the theme installed with Themler. Themler uses WP customizer functions to start. If the theme installed without Themler this feature will work. But in any case all website options which can be customized with WP Customizer can be edited using regular WP tools (menus, widgets, etc).
Hi, In order to not force the customer to purchase Themelr for editing static theme element you should use dynamic WP content instead. The widget areas with text widgets instead of the static text (footer phone number or any other text). Please understand the difference between static design elements and WP content. For any thing that you want to be changed through the WP admin panel please use WP tools (widgets and posts/pages). The Text control that you're using for phone number is the same design element as button color, for example. Simply use controls with dynamic content like widgets. The "Customizing of theme is not allowed" message appears when the theme installed with Themler. Themler uses WP customizer functions to start. If the theme installed without Themler this feature will work. But in any case all website options which can be customized with WP Customizer can be edited using regular WP tools (menus, widgets, etc). Thank you, Olivia
fcdiwi
fcdiwi posted this 13 May 2017
I am also have this problem. anyone have solution for this any code ?
Vitaliy WD
Vitaliy WD posted this 13 May 2017
Use widgets (for WP) or modules (for Joomla) or hooks (for Prestashop) etc. More info just above in this topic.
> I am also have this problem. anyone have solution for this any code ? Use widgets (for WP) or modules (for Joomla) or hooks (for Prestashop) etc. More info just above in this topic.
