Color in multilevel submenus
hovmedia
hovmedia posted this 11 May 2017
Hi!
There are settings for menus and submenus in Themler, but can I add a new color it I use a multilevel submenu?
The first level is white, then dark on next level. Some categories have a third level that I would like to give a third color.
See page:
http://dinturbutikk.no/butikk/
Hi! There are settings for menus and submenus in Themler, but can I add a new color it I use a multilevel submenu? The first level is white, then dark on next level. Some categories have a third level that I would like to give a third color. See page: http://dinturbutikk.no/butikk/
Support Team posted this 11 May 2017
There is no such option. You can set the color manually using the custom code.
Hi, There is no such option. You can set the color manually using the custom code. Sincerely, Hella
hovmedia
Do you have any desctiption on how I edit it?
Do you mean items of third level in vertical menu?
If so please try adding the following code to the Themler Settings >> Additional CSS:
.bd-menu-23 .bd-menuitem-23 > a + .bd-menu-24-popup .bd-menuitem-24 > a + .bd-menu-24-popup .bd-menu-24 .bd-menuitem-24 > a
background-color: red;
.bd-menu-23 .bd-menuitem-23 > a + .bd-menu-24-popup .bd-menuitem-24 > a + .bd-menu-24-popup .bd-menu-24 .bd-menuitem-24 > a.active
background-color: #e8a815;
This should help.
Hi, Do you mean items of third level in vertical menu? If so please try adding the following code to the Themler Settings >> Additional CSS: `.bd-menu-23 .bd-menuitem-23 > a + .bd-menu-24-popup .bd-menuitem-24 > a + .bd-menu-24-popup .bd-menu-24 .bd-menuitem-24 > a { background-color: red; } .bd-menu-23 .bd-menuitem-23 > a + .bd-menu-24-popup .bd-menuitem-24 > a + .bd-menu-24-popup .bd-menu-24 .bd-menuitem-24 > a.active { background-color: #e8a815; }` This should help. Please keep us posted about the progress. Thank you, Olivia
