5 column and widths
Mark Holland
Mark Holland posted this 15 May 2017
I am trying to create 5 columns it will only let me set 16% as soon as i try to go to 18% for all columns it messes up.
Please see the 5 column picture here.
https://dgrmanufacturing.co.uk/newsite/doors/
Hi, I am trying to create 5 columns it will only let me set 16% as soon as i try to go to 18% for all columns it messes up. Please see the 5 column picture here. https://dgrmanufacturing.co.uk/newsite/doors/ Thanks
9 Comments
Support Team posted this 15 May 2017
We are using bootstrap 12-grid system and it allows you to make a width of the column in proportion with 1/12 of the screen width (8%). You can try to make the columns 16% width and center them so they won't be aligned to the left.
Hi, We are using bootstrap 12-grid system and it allows you to make a width of the column in proportion with 1/12 of the screen width (8%). You can try to make the columns 16% width and center them so they won't be aligned to the left. Sincerely, Hella
Mark Holland
I cant centre it I have tried all the settings.
You can use this code:
.col-lg-2.col-sm-6.bd-columnwrapper-1630470389 {
    margin-left: 8%;
Add it under the Home >> Settings >> Additional CSS.
Hi, You can use this code: .col-lg-2.col-sm-6.bd-columnwrapper-1630470389 { margin-left: 8%; } Add it under the Home >> Settings >> Additional CSS. Sincerely, Hella
Mark Holland
still not working?
still not working?
Sorry, didn't realized that the class name is changed after saving. Try this one:
.col-lg-2.col-sm-6:first-child {
    margin-left: 8%;
Hi, Sorry, didn't realized that the class name is changed after saving. Try this one: .col-lg-2.col-sm-6:first-child { margin-left: 8%; } Sincerely, Hella
Mark Holland
that centralized them but the columns are still 16 and not full width, I.E beg space left and right I was to set them to 18/19/20% so they use the full width.
that centralized them but the columns are still 16 and not full width, I.E beg space left and right I was to set them to 18/19/20% so they use the full width. Thanks
As I explained in the first message, that is a bootstrap limitation and I suggested you to center them in order not to look like they are stacked to the left. You can use this code:
.col-lg-2 {
    width: 20%!important;
But some conflicts may occur with other bootstrap elements, please watch for them.
Hi, As I explained in the first message, that is a bootstrap limitation and I suggested you to center them in order not to look like they are stacked to the left. You can use this code: .col-lg-2 { width: 20%!important; } But some conflicts may occur with other bootstrap elements, please watch for them. Sincerely, Hella
Mark Holland
ok thanks I will play about with it.
Thanks Mark Holland
ok thanks I will play about with it. Thanks Mark Holland
You are welcome. Let us know if you need our further help.
You are welcome. Let us know if you need our further help. Sincerely, Hella
