Fade Effect In Sub-Menu
oscar.rivero
oscar.rivero posted this 17 May 2017
Hi, I have a trouble with my sub-menu. the transition effect doesn't work. the motion is fade and my url is
www.design.sophosdigital.com
Hi, I have a trouble with my sub-menu. the transition effect doesn't work. the motion is fade and my url is www.design.sophosdigital.com Thanks
shaulhadar
shaulhadar posted this 17 May 2017
Hi Oscar, this is a bug i also told themler team.
They said they are working on fixing this...
This bug happenes when you have a fade animation on a submenu, and you are on the active menu item.
Hi Oscar, this is a bug i also told themler team. They said they are working on fixing this... This bug happenes when you have a fade animation on a submenu, and you are on the active menu item.
oscar.rivero
Hi shaulhadar, The problem is exactly as you mention it, we will have to wait for the themler team to solve it.
Thank for your help
Hi shaulhadar, The problem is exactly as you mention it, we will have to wait for the themler team to solve it. Thank for your help
Support Team posted this 18 May 2017
Indeed, we are aware of this issue, but for now it does not have a high priority for fixing. Please follow the update logs.
Hi, Indeed, we are aware of this issue, but for now it does not have a high priority for fixing. Please follow the update logs. Sincerely, Hella
shaulhadar
shaulhadar posted this 18 May 2017
Hi Hella, thanks for the update... I would actually put a bigger priority on these types of bugs..
What i mean, is i understand you the have the other Project which takes most of the resources, and you can't give themler all the attention, but this is a visual bug inside themler, its not a new feature or something, its something that is supposed to behave normal and currently it is buggy, so these types of stuff should get the priority i think..
Please tell Oleg this, and thanks for your time :)
Hi Hella, thanks for the update... I would actually put a bigger priority on these types of bugs.. What i mean, is i understand you the have the other Project which takes most of the resources, and you can't give themler all the attention, but this is a visual bug inside themler, its not a new feature or something, its something that is supposed to behave normal and currently it is buggy, so these types of stuff should get the priority i think.. Please tell Oleg this, and thanks for your time :)
Support Team posted this 19 May 2017
Please try the following temporary workaround:
add this code to the Themler Settings >> Additional CSS:
[class*="bd-horizontalmenu"] li > .active + [class*="popup"]
opacity: 0;
[class*="bd-horizontalmenu"] li:hover > [class*="popup"]
opacity: 1;
This may help.
Hi, Please try the following temporary workaround: add this code to the Themler Settings >> Additional CSS: `[class*="bd-horizontalmenu"] li > .active + [class*="popup"] { opacity: 0; } [class*="bd-horizontalmenu"] li:hover > [class*="popup"] { opacity: 1; }` This may help. Thank you, Olivia
oscar.rivero
oscar.rivero posted this 19 May 2017
opacity: 0;
opacity: 1;
This may help.
opacity: 0;
opacity: 1;
This may help.
opacity: 0;
opacity: 1;
This may help.
Hi olivia, this is a temporal solution, i hope the themler team solve this bug in a future update.
Thanks for your help
> Hi, > > Please try the following temporary workaround: > add this code to the Themler Settings >> Additional CSS: > > `[class*="bd-horizontalmenu"] li > .active + [class*="popup"] > { > opacity: 0; > } > [class*="bd-horizontalmenu"] li:hover > [class*="popup"] > { > opacity: 1; > }` > > This may help. > > Thank you, > Olivia Hi > Hi, > > Please try the following temporary workaround: > add this code to the Themler Settings >> Additional CSS: > > `[class*="bd-horizontalmenu"] li > .active + [class*="popup"] > { > opacity: 0; > } > [class*="bd-horizontalmenu"] li:hover > [class*="popup"] > { > opacity: 1; > }` > > This may help. > > Thank you, > Olivia > Hi, > > Please try the following temporary workaround: > add this code to the Themler Settings >> Additional CSS: > > `[class*="bd-horizontalmenu"] li > .active + [class*="popup"] > { > opacity: 0; > } > [class*="bd-horizontalmenu"] li:hover > [class*="popup"] > { > opacity: 1; > }` > > This may help. > > Thank you, > Olivia Hi olivia, this is a temporal solution, i hope the themler team solve this bug in a future update. Thanks for your help
We hope that the issue will be fixed in the future updates, for now you can use a temporary solution provided above.
Hi, We hope that the issue will be fixed in the future updates, for now you can use a temporary solution provided above. Sincerely, Hella
