Split-menu with logo in center
Maykbo
Maykbo posted this 22 May 2017
I am building a website for a customer. The customer would like to have her logo in the center of the menu.
The website is going to be build in HTML.
If yes great...but how?
If no... have to check a other webbuilding program:-(
Hoping of a answer
Hi, I am building a website for a customer. The customer would like to have her logo in the center of the menu. The website is going to be build in HTML. If yes great...but how? If no... have to check a other webbuilding program:-( Hoping of a answer
Support Team posted this 22 May 2017
Unfortunately that is not available when creating the HTML sites. You can achieve such menu when creating the site for any other supported CMS.
Hi, Unfortunately that is not available when creating the HTML sites. You can achieve such menu when creating the site for any other supported CMS. Sincerely, Hella
DouzanStudio
DouzanStudio posted this 22 May 2017
Check this header styles, It's very close to what you want to achieve
http://templates.themler.com/Themes/Detail/2554568/Tourism-Simple-Header?statisticsID=100143820&selectedCategory=1318&containsInPage=True
http://templates.themler.com/Themes/Detail/2847475/Simple-Header?statisticsID=100143623&selectedCategory=1318&containsInPage=True
http://templates.themler.com/Themes/Detail/2850224/Simple-Header?statisticsID=100143623&selectedCategory=1318&containsInPage=False
Check this header styles, It's very close to what you want to achieve http://templates.themler.com/Themes/Detail/2554568/Tourism-Simple-Header?statisticsID=100143820&selectedCategory=1318&containsInPage=True http://templates.themler.com/Themes/Detail/2847475/Simple-Header?statisticsID=100143623&selectedCategory=1318&containsInPage=True http://templates.themler.com/Themes/Detail/2850224/Simple-Header?statisticsID=100143623&selectedCategory=1318&containsInPage=False
Support Team posted this 24 May 2017
Maykbo,
Do you mean that you need something like this?
[item1 item2 item3] LOGO [item4 item5 item6]
Such layout requires creating of two menus. Unfortunately in HTML theme you cannot make 2 horizontal menus with different sources. It is possible in CMS theme only.
Maykbo, Do you mean that you need something like this? [item1 item2 item3] LOGO [item4 item5 item6] Such layout requires creating of two menus. Unfortunately in HTML theme you cannot make 2 horizontal menus with different sources. It is possible in CMS theme only. Thank you, Olivia
gmmcreative
gmmcreative posted this 05 January 2018
How can you do this in WordPress?
Support Team posted this 09 January 2018
Just the same. Add two Horizontal Menu controls in Themler with the different names. Then add a Logo control between them. In WP admin panel you can set what menu will be shown in each menu location.
Hi, Just the same. Add two Horizontal Menu controls in Themler with the different names. Then add a Logo control between them. In WP admin panel you can set what menu will be shown in each menu location. Sincerely, Hella
DaveOzric
DaveOzric posted this 10 December 2018
That is not a good solution. Can you offer a better way not that it's a year later?
lynnmonk
lynnmonk posted this 10 December 2018
In Wordpress, I would create two menus like has already been suggested. In HTML I would create individual links to pages instead of a "menu" control.
