joomla edit template not active
Rubinowe
Rubinowe posted this 25 May 2017
Joomla - edit template button don't work, it is not active.
Previously everything worked.
The problem is on many pages.
I need to regain access to edit templates. What happened and what to do.
I'm sending a screen.
Hi Joomla - edit template button don't work, it is not active. Previously everything worked. The problem is on many pages. I need to regain access to edit templates. What happened and what to do. I'm sending a screen.
11 Comments
Support Team posted this 25 May 2017
Please try the following suggestions:
http://answers.themler.com/articles/65488/troubleshooting-read-first
Also try to switch off all the site plug-ins to see if any of them is causing the issue.
Hi, Please try the following suggestions: http://answers.themler.com/articles/65488/troubleshooting-read-first Also try to switch off all the site plug-ins to see if any of them is causing the issue. Sincerely, Hella
Vitaliy WD
Vitaliy WD posted this 25 May 2017
Hi.
Here what you can try to do:
1.Open <theme_name>/app/classes/Config.php file
2.Find the following line:
$editor = JRequest::getVar('editor', '');
and insert the following piece of code before it
JHtml::_ ( 'behavior.modal' ); // for SqueezeBox
After this open a template and update it to the latest version.
Hi. Here what you can try to do: 1.Open &lt;theme_name&gt;/app/classes/Config.php file 2.Find the following line: $editor = JRequest::getVar('editor', ''); and insert the following piece of code before it JHtml::_ ( 'behavior.modal' ); // for SqueezeBox After this open a template and update it to the latest version.
rein
rein posted this 06 June 2017
This works perfectly, thank you
peggybaussart
peggybaussart posted this 09 August 2017
Thank you Vitaliy WD
jmstark
jmstark posted this 10 September 2017
Same problem. Added the line of code, changed permissions and the button now works BUT the live site editor does not load. It begins to load and stops. On Chrome, the home page of the site shows. On MS Edge, blank screen. The MS Edge inspector show the warning:
"Resource doesn't exist on the server: 'http://southmissco.com/administrator/index.php?option=com_templates&view=style&layout=edit&id=38&editor=1&theme=itsolutions&ver=178'."
Related problem?
Same problem. Added the line of code, changed permissions and the button now works BUT the live site editor does not load. It begins to load and stops. On Chrome, the home page of the site shows. On MS Edge, blank screen. The MS Edge inspector show the warning: "Resource doesn't exist on the server: 'http://southmissco.com/administrator/index.php?option=com_templates&view=style&layout=edit&id=38&editor=1&theme=itsolutions&ver=178'." Related problem?
Support Team posted this 11 September 2017
jmstark,
Please try to load Themler in Chrome. If the issue continues please create a new private topic and provide the access to the CMS admin panel.
jmstark, Please try to load Themler in Chrome. If the issue continues please create a new private topic and provide the access to the CMS admin panel. Thank you, Olivia
kharding23
kharding23 posted this 30 November 2017
Problem solved. Thank you for your help. I was in an old folder. The code for SqueezeBox did the trick.
MercurioWeb WebStudio
MercurioWeb WebStudio posted this 2 weeks ago
Hi, I changed the config.php file, as indicated, but the problem persists. When I try to edit the template from the joomla control panel, blank page comes out
Have you updated Joomla to 3.9 recently?
If so, please follow these steps to fix the current theme:
https://answers.themler.io/articles/173620/how-to-fix-the-error-after-updating-to-joomla-3-9
After this update the theme to the latest Themler version that supports Joomla 3.9.
Hello, Have you updated Joomla to 3.9 recently? If so, please follow these steps to fix the current theme: https://answers.themler.io/articles/173620/how-to-fix-the-error-after-updating-to-joomla-3-9 After this update the theme to the latest Themler version that supports Joomla 3.9. Sincerely, Nettie
MercurioWeb WebStudio posted this 2 days ago
Hi, I followed the instructions, but now the following error comes out:
[PHP_ERROR]{"message":"\n\nOS: Linux lhcp1088.webapps.net 2.6.32-773.26.1.lve1.4.43.el6.x86_64 #1 SMP Mon Oct 30 02:31:47 EDT 2017 x86_64\nPHP: 7.2.8\nerror handler: A non well formed numeric value encountered\nArray\n(\n [value] => 128M\n [str] => 128m\n)\n Callstack: \n -> Helper::toBytes('128M')\n -> Helper::getMemoryLimit()\n -> Helper::tryAllocateMemory()\n -> ExportController::execute(array(4) { ... })\n\n\n","type":"E_NOTICE","file":"/home/sapr/public_html/templates/rilievispar/app/classes/Helper.php","line":586}[PHP_ERROR]
> Hello, > > Have you updated Joomla to 3.9 recently? > If so, please follow these steps to fix the current theme: > https://answers.themler.io/articles/173620/how-to-fix-the-error-after-updating-to-joomla-3-9 > After this update the theme to the latest Themler version that supports Joomla 3.9. > > Sincerely, > Nettie > > Hi, I followed the instructions, but now the following error comes out: [PHP_ERROR]{"message":"\n\nOS: Linux lhcp1088.webapps.net 2.6.32-773.26.1.lve1.4.43.el6.x86_64 #1 SMP Mon Oct 30 02:31:47 EDT 2017 x86_64\nPHP: 7.2.8\nerror handler: A non well formed numeric value encountered\nArray\n(\n [value] => 128M\n [str] => 128m\n)\n Callstack: \n -> Helper::toBytes('128M')\n -> Helper::getMemoryLimit()\n -> Helper::tryAllocateMemory()\n -> ExportController::execute(array(4) { ... })\n\n\n","type":"E_NOTICE","file":"\/home\/sapr\/public_html\/templates\/rilievispar\/app\/classes\/Helper.php","line":586}[PHP_ERROR]
Support Team posted this yesterday
Hi Massimiliano,
Please create a new private thread so that we can dig deeper into your issue.
Ivan
Hi Massimiliano, Please create a new private thread so that we can dig deeper into your issue. Thanks, Ivan
