Multi Line Menu with Joomla
enyonam
enyonam posted this 25 May 2017
How do i create Multi Line Menu for Joomla in themler.
I want my menu items to break when the Item is more than two words.
Eg: A menu item like Men's Fashion will be converted to Men's on top and Fashion below.
Similar to this thread.
How do i create Multi Line Menu for Joomla in themler. I want my menu items to break when the Item is more than two words. Eg: A menu item like Men's Fashion will be converted to Men's on top and Fashion below. [Similar to this thread.][1] [1]: http://answers.themler.com/questions/55419/multiline-menu-item-for-wordpress
8 Comments
Support Team posted this 26 May 2017
Thee is a solution described in the link you have provided. Do you have any problems with it?
Hi, Thee is a solution described in the link you have provided. Do you have any problems with it? Sincerely, Hella
enyonam
enyonam posted this 26 May 2017
I cant find the solution. I have tried all that was suggested. Please point it out to me. Thank you
> Hi, > > Thee is a solution described in the link you have provided. Do you have any problems with it? > > Sincerely, > Hella I cant find the solution. I have tried all that was suggested. Please point it out to me. Thank you
Open the Menu Item >> More Options and set the desired max-width value and the white space option to pre-wrap.
Hi, Open the Menu Item >> More Options and set the desired max-width value and the white space option to pre-wrap. Sincerely, Hella
enyonam
This did not work.
> Hi, > > Open the Menu Item >> More Options and set the desired max-width value and the white space option to pre-wrap. > > Sincerely, > Hella This did not work.
Please provide a link to your site so we could help you with the code.
Hi, Please provide a link to your site so we could help you with the code. Sincerely, Hella
roberto.torres.aguayo
roberto.torres.aguayo posted this 07 September 2017
I also have this problem... i tryed fixing the sidebar and didnt work, the menu and didnt work,,
roberto.torres.aguayo posted this 08 September 2017
this is the link https://goo.gl/ZGUuz2
> I also have this problem... i tryed fixing the sidebar and didnt work, the menu and didnt work,, this is the link https://goo.gl/ZGUuz2
Support Team posted this 08 September 2017
Please create a private topic with the access to the site back end so we could review the settings. As I understand, you want your orange menu in the sidebar to have menu items going on the next line when they exceed the width of the sidebar?
Hi, Please create a private topic with the access to the site back end so we could review the settings. As I understand, you want your orange menu in the sidebar to have menu items going on the next line when they exceed the width of the sidebar? Sincerely, Hella
