PHP Error by all sites
matrix630307
matrix630307 posted this 26 May 2017
hi
on sites, i become the error-message here, when i will open the themplate with themler:
[PHP_ERROR]{"message":"\n\nOS: Linux tux355 4.8.11-hoststar #1 SMP Tue Nov 29 13:39:39 CET 2016 x86_64\nPHP: 7.1.1\nerror handler: A non well formed numeric value encountered\nArray\n(\n [value] => 128M\n [str] => 128m\n)\n Callstack: \n -> Helper::toBytes('128M')\n -> Helper::getMemoryLimit()\n -> Helper::tryAllocateMemory()\n -> ExportController::execute(array(4) { ... })\n\n\n","type":"E_NOTICE","file":"/home/www/web146/html/cms/templates/mbstadtrat01/app/classes/Helper.php","line":586}[PHP_ERROR]
This is the example, when i will open the themplate from domain markusbirck.ch. What is this?
hi on sites, i become the error-message here, when i will open the themplate with themler: [PHP_ERROR]{"message":"\n\nOS: Linux tux355 4.8.11-hoststar #1 SMP Tue Nov 29 13:39:39 CET 2016 x86_64\nPHP: 7.1.1\nerror handler: A non well formed numeric value encountered\nArray\n(\n [value] => 128M\n [str] => 128m\n)\n Callstack: \n -> Helper::toBytes('128M')\n -> Helper::getMemoryLimit()\n -> Helper::tryAllocateMemory()\n -> ExportController::execute(array(4) { ... })\n\n\n","type":"E_NOTICE","file":"\/home\/www\/web146\/html\/cms\/templates\/mbstadtrat01\/app\/classes\/Helper.php","line":586}[PHP_ERROR] This is the example, when i will open the themplate from domain markusbirck.ch. What is this?
Support Team posted this 27 May 2017
Looks like the old issue related to incompatibility with php 7.1.1 which we fixed in the last Themler update. What php version is running on your server?
Is i possible to downgrade it and upgrade the theme? Or you can download theme bu FTP, open in Themler desktop and update theme there.
Hi, Looks like the old issue related to incompatibility with php 7.1.1 which we fixed in the last Themler update. What php version is running on your server? Is i possible to downgrade it and upgrade the theme? Or you can download theme bu FTP, open in Themler desktop and update theme there. Thank you, Olivia
matrix630307
matrix630307 posted this 27 May 2017
i have on all sites php 7.1.1 and the message from my first post.
when i go back to 7.0 with htaccess-demand, then i can update. but you make not a possible version that this error will not show and i can update directly?
i have on all sites php 7.1.1 and the message from my first post. when i go back to 7.0 with htaccess-demand, then i can update. but you make not a possible version that this error will not show and i can update directly?
Support Team posted this 28 May 2017
Unfortunately there is no way to update the theme without downgrading your PHP version once you have already updated the theme to the version with the issue. So you need to downgrade the PHP version or use a desktop version to update the theme.
Hi, Unfortunately there is no way to update the theme without downgrading your PHP version once you have already updated the theme to the version with the issue. So you need to downgrade the PHP version or use a desktop version to update the theme. Sincerely, Hella
matrix630307
matrix630307 posted this 28 May 2017
ok - it's a little bit strange, but goes....
thank you
ok - it's a little bit strange, but goes.... thank you
online9
online9 posted this 27 November 2017
I have the same problem. I am running PHP v7.0.25. Downgraded to PHPv 5.6 (just in case) but no change. Any other thoughts?
I can edit themes on other joomla sites within the same shared hosting environment - same PHP versions.
I have tried disabling plugins installed recently - no change.
Message is like:
PHP_ERROR]{"message":"\n\nOS: Linux r118.websiteservername.com 3.10.0-714.10.2.lve1.4.74.el7.x86_64 #1 SMP Wed Oct 11 15:51:10 EDT 2017 x86_64\nPHP: 7.0.25\nerror handler: Undefined variable: accepted\nArray\n(\n [CBlog] => \/home\/lakeferryadmin\/public_html\/plugins\/system\/botipblocker\/botipblocker_log.txt\n [mainframe] => Joomla\\CMS\\Application\\AdministratorApplication Object\n (\n [docOptions:protected] => Array\n (\n [template] => isis\n [file] => themler.php\n [params] => Joomla\\Registry\\Registry Object\n (\n [data:protected] => stdClass Object\n (\n [templateColor] => \n [logoFile] => \n )\n\n [initialized:protected] => 1\n [separator] => .\n )\n\n [directory] => \/home\/lakeferryadmin\/public_html\/administrator\/templates\n )\n\n [scope] => \n [_clientId:protected] => 1\n [_messageQueue:protected] => Array\n (\n )\n\n [_name:protected] => administrator\n [profiler:protected] => \n [template:protected] => stdClass Object\n (\n [template] => isis\n [params] => Joomla\\Registry\\Registry Object\n (\n [data:protected] => stdClass Object\n (\n [templateColor] => \n [logoFile] => \n )\n\n [initialized:protected] => 1\n [separator] => .\n )\n\n )\n\n [charSet] => utf-8\n [mimeType] => text\/html\n [modifiedDate] => \n [client] => Joomla\\Application\\Web\\WebClient Object\n (\n [platform:protected] => \n [mobile:protected] => \n [engine:protected] => \n [browser:protected] => \n [browserVersion:protected] => \n [languages:protected] => Array\n (\n )\n\n [encodings:protected] => Array\n (\n )\n\n [userAgent:protected] => Mozilla\/5.0 (Windows NT 6.1; Win64; x64) AppleWebKit\/537.36 (KHTML, like Gecko) Chrome\/62.0.3202.94 Safari\/537.36\n [acceptEncoding:protected] => gzip\n [acceptLanguage:protected] => en-NZ,en-GB;q=0.9,en-US;q=0.8,en;q=0.7\n [robot:protected] => \n [detection:protected] => Array\n (\n )\n\n [headers:protected] => \n )\n\n [document:protected] => Joomla\\CMS\\Document\\HtmlDocument Object\n (\n [_links] => Array\n (\n [\/administrator\/templates\/isis\/favicon.ico] => Array\n (\n [relation] => shortcut icon\n [relType] => rel\n [attribs] => Array\n (\n [type] => image\/vnd.microsoft.icon\n )\n\n )\n\n )\n\n [_custom] => Array\n (\n )\n\n [template] => isis\n [baseurl] => \/administrator\n [params] => Joomla\\Registry\\Registry Object\n (\n [data:protected] => stdClass Object\n (\n [templateColor] => \n [logoFile] => \n )\n\n [initialized:protected] => 1\n [separator] => .\n )\n\n [_file] => \/home\/lakeferryadmin\/public_html\/administrator\/templates\/isis\/themler.php\n [_template:protected] => \n\n\n \n \n
I have the same problem. I am running PHP v7.0.25. Downgraded to PHPv 5.6 (just in case) but no change. Any other thoughts? I can edit themes on other joomla sites within the same shared hosting environment - same PHP versions. I have tried disabling plugins installed recently - no change. Message is like: PHP_ERROR]{"message":"\n\nOS: Linux r118.websiteservername.com 3.10.0-714.10.2.lve1.4.74.el7.x86_64 #1 SMP Wed Oct 11 15:51:10 EDT 2017 x86_64\nPHP: 7.0.25\nerror handler: Undefined variable: accepted\nArray\n(\n [CBlog] => \/home\/lakeferryadmin\/public_html\/plugins\/system\/botipblocker\/botipblocker_log.txt\n [mainframe] => Joomla\\CMS\\Application\\AdministratorApplication Object\n (\n [docOptions:protected] => Array\n (\n [template] => isis\n [file] => themler.php\n [params] => Joomla\\Registry\\Registry Object\n (\n [data:protected] => stdClass Object\n (\n [templateColor] => \n [logoFile] => \n )\n\n [initialized:protected] => 1\n [separator] => .\n )\n\n [directory] => \/home\/lakeferryadmin\/public_html\/administrator\/templates\n )\n\n [scope] => \n [_clientId:protected] => 1\n [_messageQueue:protected] => Array\n (\n )\n\n [_name:protected] => administrator\n [profiler:protected] => \n [template:protected] => stdClass Object\n (\n [template] => isis\n [params] => Joomla\\Registry\\Registry Object\n (\n [data:protected] => stdClass Object\n (\n [templateColor] => \n [logoFile] => \n )\n\n [initialized:protected] => 1\n [separator] => .\n )\n\n )\n\n [charSet] => utf-8\n [mimeType] => text\/html\n [modifiedDate] => \n [client] => Joomla\\Application\\Web\\WebClient Object\n (\n [platform:protected] => \n [mobile:protected] => \n [engine:protected] => \n [browser:protected] => \n [browserVersion:protected] => \n [languages:protected] => Array\n (\n )\n\n [encodings:protected] => Array\n (\n )\n\n [userAgent:protected] => Mozilla\/5.0 (Windows NT 6.1; Win64; x64) AppleWebKit\/537.36 (KHTML, like Gecko) Chrome\/62.0.3202.94 Safari\/537.36\n [acceptEncoding:protected] => gzip\n [acceptLanguage:protected] => en-NZ,en-GB;q=0.9,en-US;q=0.8,en;q=0.7\n [robot:protected] => \n [detection:protected] => Array\n (\n )\n\n [headers:protected] => \n )\n\n [document:protected] => Joomla\\CMS\\Document\\HtmlDocument Object\n (\n [_links] => Array\n (\n [\/administrator\/templates\/isis\/favicon.ico] => Array\n (\n [relation] => shortcut icon\n [relType] => rel\n [attribs] => Array\n (\n [type] => image\/vnd.microsoft.icon\n )\n\n )\n\n )\n\n [_custom] => Array\n (\n )\n\n [template] => isis\n [baseurl] => \/administrator\n [params] => Joomla\\Registry\\Registry Object\n (\n [data:protected] => stdClass Object\n (\n [templateColor] => \n [logoFile] => \n )\n\n [initialized:protected] => 1\n [separator] => .\n )\n\n [_file] => \/home\/lakeferryadmin\/public_html\/administrator\/templates\/isis\/themler.php\n [_template:protected] => \n\n\n \n \n
Support Team posted this 27 November 2017
Hi Paul,
May we ask you to create a new private ticket and provide us with a temp access to your Joomla back-end there so we can try to help you.
Ivan
Hi Paul, May we ask you to create a new private ticket and provide us with a temp access to your Joomla back-end there so we can try to help you. Thanks, Ivan
support93
support93 posted this 2 weeks ago
I have the same error on all my site but no one answers me !
Hello, I have the same error on all my site but no one answers me !
