Virtuemart Product navigation
mladen.karlovcec
mladen.karlovcec posted this 31 May 2017
i can not find how to enable product navigation for virtuemart.
On a Artister template the navigation is working, on the themler template it's not.
THEMLER
ARTISTER
Hello, i can not find how to enable product navigation for virtuemart. On a Artister template the navigation is working, on the themler template it's not. ![THEMLER][1] ![ARTISTER][2] [1]: https://i.imgur.com/UEWjR4Z.jpg [2]: https://i.imgur.com/a5O5GY5.jpg
10 Comments
Support Team posted this 31 May 2017
Unfortunately Themler team does not provide such control. You can try adding this element manually using custom code in the CMS Code control.
Hi, Unfortunately Themler team does not provide such control. You can try adding this element manually using custom code in the CMS Code control. Thank you, Olivia
Juan Padilla
Juan Padilla posted this 17 August 2017
Hi, what is the code that I should add and in what files?
César Mendoza
César Mendoza posted this 17 August 2017
Here I leave the code to do that ...
Just embed a CMS control in product details and that's it.
Here I leave the code to do that ... Just embed a CMS control in product details and that's it.
Juan Padilla
Gracias César, lo probaré
Juan Padilla
Lo probé pero no aparece, sólo aparace el espacio vacío. Alguna sugerencia?
Juan Padilla
Lo intenté agregar en el archivo productoverview.php del template generado por themler, pero no funciona. Será otro el archivo que debo intervenir?
Juan Padilla
Juan Padilla posted this 18 August 2017
El archivo a modificar es default_template.php, ruta TEMPLATE/html/com_virtuemart/productdetails
Support Team posted this 29 August 2017
Simply add "CMS Code" control to the Product Details template and insert the following code (from the VM source files):
<?php
    // Product Navigation
    if (VmConfig::get('product_navigation', 1)) {
        <div class="product-neighbours">
        <?php
        if (!empty($this->product->neighbours ['previous'][0])) {
        $prev_link = JRoute::_('index.php?option=com_virtuemart&view=productdetails&virtuemart_product_id=' . $this->product->neighbours ['previous'][0] ['virtuemart_product_id'] . '&virtuemart_category_id=' . $this->product->virtuemart_category_id, FALSE);
        echo JHtml::_('link', $prev_link, $this->product->neighbours ['previous'][0]
            ['product_name'], array('rel'=>'prev', 'class' => 'previous-page','data-dynamic-update' => '1'));
        if (!empty($this->product->neighbours ['next'][0])) {
        $next_link = JRoute::_('index.php?option=com_virtuemart&view=productdetails&virtuemart_product_id=' . $this->product->neighbours ['next'][0] ['virtuemart_product_id'] . '&virtuemart_category_id=' . $this->product->virtuemart_category_id, FALSE);
        echo JHtml::_('link', $next_link, $this->product->neighbours ['next'][0] ['product_name'], array('rel'=>'next','class' => 'next-page','data-dynamic-update' => '1'));
        <div class="clear"></div>
        </div>
    <?php } // Product Navigation END
That's all.
Hi, Simply add "CMS Code" control to the Product Details template and insert the following code (from the VM source files): <?php // Product Navigation if (VmConfig::get('product_navigation', 1)) { ?> <div class="product-neighbours"> <?php if (!empty($this->product->neighbours ['previous'][0])) { $prev_link = JRoute::_('index.php?option=com_virtuemart&view=productdetails&virtuemart_product_id=' . $this->product->neighbours ['previous'][0] ['virtuemart_product_id'] . '&virtuemart_category_id=' . $this->product->virtuemart_category_id, FALSE); echo JHtml::_('link', $prev_link, $this->product->neighbours ['previous'][0] ['product_name'], array('rel'=>'prev', 'class' => 'previous-page','data-dynamic-update' => '1')); } if (!empty($this->product->neighbours ['next'][0])) { $next_link = JRoute::_('index.php?option=com_virtuemart&view=productdetails&virtuemart_product_id=' . $this->product->neighbours ['next'][0] ['virtuemart_product_id'] . '&virtuemart_category_id=' . $this->product->virtuemart_category_id, FALSE); echo JHtml::_('link', $next_link, $this->product->neighbours ['next'][0] ['product_name'], array('rel'=>'next','class' => 'next-page','data-dynamic-update' => '1')); } ?> <div class="clear"></div> </div> <?php } // Product Navigation END ?> That's all. Thank you, Olivia
reinhard
reinhard posted this 11 September 2017
I add the CMS Code above the Product Details page.
Than I copy > past your code
But doesn' work only a 404 error comes up :(
What do I wrong?
I add the CMS Code above the Product Details page. Than I copy > past your code But doesn' work only a 404 error comes up :( What do I wrong?
Support Team posted this 12 September 2017
The code works ok on my side as well ad created links to products:
Could you please create a new private topic and provide the access to the Joomla admin panel.
Hi, The code works ok on my side as well ad created links to products: !product-nav.png! Could you please create a new private topic and provide the access to the Joomla admin panel. Thank you, Olivia
