Themler v.379 Hot-Fix Update (7-June-2017)
Support Team posted this 02 June 2017
Hi everyone!
We resolved issues found after last major Themler v.367 update and updated Themler to the new 379 version.
Here is list of fixes:
  • Fixed memory limit errors in Joomla, WordPress, PrestaShop and Drupal themes.
  • Fixed issue with Products template in Joomla+VirtueMart
  • A few more fixes to improve compatibility with Woocommerc 3.
  • Fixed issue with exporting Joomla themes (broken archive).
  • Fixed issue with "login to read more" feature in Joomla.
  • Fixed a few more Themler crashes in Joomla.
  • A few more minor fixes.
Themler team
Hi everyone! We resolved issues found after last major Themler v.367 update and updated Themler to the new 379 version. Here is list of fixes: - Fixed memory limit errors in Joomla, WordPress, PrestaShop and Drupal themes. - Fixed issue with Products template in Joomla+VirtueMart - A few more fixes to improve compatibility with Woocommerc 3. - Fixed issue with exporting Joomla themes (broken archive). - Fixed issue with "login to read more" feature in Joomla. - Fixed a few more Themler crashes in Joomla. - A few more minor fixes. Thank you, Themler team
46 Comments
Stagger Lee posted this 11 June 2017
It can look like unnecessary complaining. What is wrong with developing 2 products, it is only on positive side.
But it is not. Magento is not supported. Drupal is lagging behind, and much is missing.
Nobody will install Magento 1.x just because of Themler.
What happens when Prestashop decide to change structure of its code in bigger way ? As Drupal and Magento did.
I see it as wasting of resources. To build "another product" when money and coders could be used to follow all CMS updates and make Themler catch in pace.
It can look like unnecessary complaining. What is wrong with developing 2 products, it is only on positive side. But it is not. Magento is not supported. Drupal is lagging behind, and much is missing. Nobody will install Magento 1.x just because of Themler. What happens when Prestashop decide to change structure of its code in bigger way ? As Drupal and Magento did. I see it as wasting of resources. To build "another product" when money and coders could be used to follow all CMS updates and make Themler catch in pace.
I did not know, new Prestashop versions are not supported in Themler. It is really waste of time to build new product when things like this are left behind. Use that money in better way.
http://answers.themler.com/questions/121312/prestashop-1-7-update
I did not know, new Prestashop versions are not supported in Themler. It is really waste of time to build new product when things like this are left behind. Use that money in better way. http://answers.themler.com/questions/121312/prestashop-1-7-update
Vitaliy WD
Vitaliy WD posted this 11 June 2017
Or even one On/Off switch in Themler. You click to Off, and Themler
GUI interface switch to beginners mode. In beginners mode you can
assume people dont know how to use "CMS control". Hover box, shortcode
control and many others. Remove all Posts options and give them only
prepared layouts, etc...
Great idea by the way! Themler team, look at this. I think this really can be good solution. Expert mode switch like in Smart Slider 3. Here is a demo example: https://youtu.be/orld-gwFG5A.
I tested it and was not impressed at all.
Me too...
> Or even one On/Off switch in Themler. You click to Off, and Themler > GUI interface switch to beginners mode. In beginners mode you can > assume people dont know how to use "CMS control". Hover box, shortcode > control and many others. Remove all Posts options and give them only > prepared layouts, etc... Great idea by the way! Themler team, look at this. I think this really can be good solution. Expert mode switch like in [Smart Slider 3][1]. Here is a demo example: https://youtu.be/orld-gwFG5A. > I tested it and was not impressed at all. Me too... [1]: https://smartslider3.com/
Rune
Rune posted this 12 June 2017
Looking forward to the WooCommerce cart-update. Remeber to add the correct translation strings to cart buttons.
Looking forward to the WooCommerce cart-update. Remeber to add the correct translation strings to cart buttons. !Udklip.JPG!
GuPatrolOh3
GuPatrolOh3 posted this 12 June 2017
When will a fix be out to fix checkout files for Magento? 1.9.3.3 requires FormKey scripting.
Support Team posted this 13 June 2017
We considered such option. But it is quite difficult to implement it at the current stage of Themler evolution.
We've included a fix for this issue in the last Themler hot-fix update.
Bu this is just a question of text comment in the file. It does not affect anything.
If you faced any problems with Magneto 1.9 checkout and have not reported them previously please create a new private topic and describe the issue in details.
Hi, > Or even one On/Off switch in Themler. You click to Off, and Themler GUI interface switch to beginners mode. We considered such option. But it is quite difficult to implement it at the current stage of Themler evolution. > Looking forward to the WooCommerce cart-update. Remeber to add the correct translation strings to cart buttons. We've included a fix for this issue in the last Themler hot-fix update. Bu this is just a question of text comment in the file. It does not affect anything. > When will a fix be out to fix checkout files for Magento? 1.9.3.3 requires FormKey scripting. If you faced any problems with Magneto 1.9 checkout and have not reported them previously please create a new private topic and describe the issue in details. Thank you, Olivia
Stagger Lee posted this 18 June 2017
Bug in Paragraphs Options - paddings is still not fixed. Very difficult to set paddings. First time it goes, but not easy when you want to change it. It is stuck to first you chosed. "Clear" doesnt work too.
Vitaliy WD
Vitaliy WD posted this 19 June 2017
Do you use spacing "After" for paragraphs padding?
> Bug in Paragraphs Options - paddings is still not fixed. Very difficult to set paddings. First time it goes, but not easy when you want to change it. It is stuck to first you chosed. "Clear" doesnt work too. Do you use spacing "After" for paragraphs padding?
Stagger Lee posted this 19 June 2017
Usually I set all those options to zero, almost all the time for Titles and H tags. Except Line Height.
Why ?
Usually I set all those options to zero, almost all the time for Titles and H tags. Except Line Height. Why ?
Vitaliy WD
Why ?
Same here... usually I'm set it to zero for H1-H6. But not always, sometime it's better, when by default there is paddings, sometime not... Strange that there is empty fields when paddings set by default and need to set it to zero if you want to clear it.
> Usually I set all those options to zero, almost all the time for Titles and H tags. Except Line Height. > Why ? Same here... usually I'm set it to zero for H1-H6. But not always, sometime it's better, when by default there is paddings, sometime not... Strange that there is empty fields when paddings set by default and need to set it to zero if you want to clear it.
srathje
srathje posted this 20 June 2017
This "another product" is waste of time. Dont know why they lose time on it.
Many of Themler users don't want to learn how work with Themler, what is Bootrstap, Grid system, basic CSS options etc. They want create "awesome" websites with few mouse clicks. Sad but truth.
Yeah, but no. I gave up on Themler about 4 months ago. Only use it for my legacy websites now. Haven't bothered to purchase a renewal. Themler was constantly aggravating me and added 3x amount of time to website development. The bugs, the general slowness, inconsistency of the GUI, and the sloppy html/css it produces. I switched to Beaver Builder and Beaver Themer, and this is what Themler should of been. Granted it is only for Wordpress, it does what Themler does, 10x better and it is super easy to add custom code, or override CSS. It is lightning fast.
> > This "another product" is waste of time. Dont know why they lose time on it. > > Many of Themler users don't want to learn how work with Themler, what is Bootrstap, Grid system, basic CSS options etc. They want create "awesome" websites with few mouse clicks. Sad but truth. Yeah, but no. I gave up on Themler about 4 months ago. Only use it for my legacy websites now. Haven't bothered to purchase a renewal. Themler was constantly aggravating me and added 3x amount of time to website development. The bugs, the general slowness, inconsistency of the GUI, and the sloppy html/css it produces. I switched to Beaver Builder and Beaver Themer, and this is what Themler should of been. Granted it is only for Wordpress, it does what Themler does, 10x better and it is super easy to add custom code, or override CSS. It is lightning fast.
gcg
gcg posted this 23 June 2017
Hi Themler team,
If the current version is stable, why is not listed on update log? Have bugs?
Hi Themler team, If the current version is stable, why is not listed on update log? Have bugs? Thanks
Support Team posted this 23 June 2017
Hi.
The current update is the hotfix update for stable version. It is quite stable.
Hi. The current update is the hotfix update for stable version. It is quite stable. Thank you, Olivia
jjkieffer
jjkieffer posted this 23 June 2017
What is that "other product" 's name?
What is that "other product" 's name? Regards
gcg
gcg posted this 10 July 2017
I have tested v.379 today with the latest update of Joomla 3.7.3 with out errors. I use cloud Themler version (on my host) and use it only for template creation, not as content editor.
I see that there are a new beta, what fix this new version? When will be stable?
Hi, I have tested v.379 today with the latest update of Joomla 3.7.3 with out errors. I use cloud Themler version (on my host) and use it only for template creation, not as content editor. I see that there are a new beta, what fix this new version? When will be stable? Thanks
Support Team posted this 13 July 2017
There are a few Joomla and VM fixes:
- VM one page checkout
- fixed issue with preview links in joomla
- fixed issue with joomla post image floating
- fixed issue with VM modules and products
- a few more minor fixes.
Hi, There are a few Joomla and VM fixes: - VM one page checkout - fixed issue with preview links in joomla - fixed issue with joomla post image floating - fixed issue with VM modules and products - a few more minor fixes. Thank you, Olivia
pdg.design
pdg.design posted this 13 July 2017
v.382 have many bugs...
DaveOzric
DaveOzric posted this 13 July 2017
No HTTPS for Google fonts in HTML5 sites?
No Page Heading H1 in Joomla?
Why?
No HTTPS for Google fonts in HTML5 sites? No Page Heading H1 in Joomla? Why?
Support Team posted this 14 July 2017
What exactly bugs? Could you please report them in a separate topics with detailed description?
No, unfortunately.
I think I see the light in the end of the tunnel of discussing this issue with our developers :-)
We reached an agreement and currently I'm waiting for the fix in development version for testing.
Hi, > v.382 have many bugs... What exactly bugs? Could you please report them in a separate topics with detailed description? > No HTTPS for Google fonts in HTML5 sites? No, unfortunately. > No Page Heading H1 in Joomla? I think I see the light in the end of the tunnel of discussing this issue with our developers :-) We reached an agreement and currently I'm waiting for the fix in development version for testing. Thank you, Olivia
DaveOzric
DaveOzric posted this 14 July 2017
OMG! I am very happy to hear you say this. You have no idea how grateful I would be.
Thank you Olivia!
OMG! I am very happy to hear you say this. You have no idea how grateful I would be. Thank you Olivia!
