Where is my ZIP file saving
dilani
dilani posted this 03 June 2017
I use a mac. I just finished a Themler wordpress theme, but I don't know where the folder is. Please help . Thanks Dilani
Hi, I use a mac. I just finished a Themler wordpress theme, but I don't know where the folder is. Please help . Thanks Dilani
Support Team posted this 05 June 2017
Please search in the Documents or Downloads folders.
Hi, Please search in the Documents or Downloads folders. Sincerely, Hella
lrgrl
lrgrl posted this 10 February 2019
Did this get resolved?
dilani
dilani posted this 10 February 2019
Thankyou. I will see if this works. I appreciate your reply
Support Team posted this 11 February 2019
If you still cannot locate the file, please try to open Themler through a browser using a link like this
http://127.0.0.1:29958/themler_XXXXXXXXXX/startup/
The exact numbers are visible in Themler Live Preview.
Try different browsers like Safari, Firefox, Chrome and to export.
As a temporary solution, you may copy the theme manually from the folder with themes. Please click Go >> Go to Folder >> type ~/Library and ENTER >> Themler >> hd_data >> cms >> choose CMS and access the themes folder, copy the theme, zip it and install on your hosted website.
Hello, If you still cannot locate the file, please try to open Themler through a browser using a link like this http://127.0.0.1:29958/themler_XXXXXXXXXX/startup/ The exact numbers are visible in Themler Live Preview. Try different browsers like Safari, Firefox, Chrome and to export. As a temporary solution, you may copy the theme manually from the folder with themes. Please click Go >> Go to Folder >> type `~/Library` and ENTER >> Themler >> hd_data >> cms >> choose CMS and access the themes folder, copy the theme, zip it and install on your hosted website. Sincerely, Nettie
