Sections Not staying in one place
dilani
dilani posted this 06 June 2017
Hi I reported this before on an e-mail but it seems to have vanished. My 2nd section is going UNDER my Banner section It's like my banner section keeps floating on top of it. You can see it in the passive section that I have a video and a two column page and you can see it in y active section that it has gone under the first section that holds my banner. I don't understand how this has happened. It just did.
Could you please help.
The first screen shot is the static page and the 2ndf one is the dynamic page.
Thanks.
Hi I reported this before on an e-mail but it seems to have vanished. My 2nd section is going UNDER my Banner section It's like my banner section keeps floating on top of it. You can see it in the passive section that I have a video and a two column page and you can see it in y active section that it has gone under the first section that holds my banner. I don't understand how this has happened. It just did. Could you please help. The first screen shot is the static page and the 2ndf one is the dynamic page. Thanks.
6 Comments
Support Team posted this 06 June 2017
You have a lot of positioning set to absolute value in your theme. That is not a good practice for the layout, especially when it comes in responsive. In you case please open the Header control options in the right panel and set the Position value to relative. And avoid using the absolute positioning in the future.
Hi, You have a lot of positioning set to `absolute` value in your theme. That is not a good practice for the layout, especially when it comes in responsive. In you case please open the Header control options in the right panel and set the Position value to `relative`. And avoid using the absolute positioning in the future. Sincerely, Hella
dilani
I did change it. But it is still having the same effect.
Support Team posted this 07 June 2017
Could you please attach the edited theme. The old theme феесрув to another ticket looks just fine on my end.
Hi, Could you please attach the edited theme. The old theme феесрув to another ticket looks just fine on my end. Sincerely, Hella
dilani
dilani posted this 07 June 2017
The first thumbnail is the " inactive theme on the side" you can see that there is a section with a video. The 2nd one is the actual live theme. The video section is under the banner and if I delete it the section which has three columns moves up and underneath it.... ( the banner section)
Support Team posted this 08 June 2017
Could you please attach the current version of your theme.
Hi, Could you please attach the current version of your theme. Sincerely, Hella
dilani
dilani posted this 09 June 2017
Thanks Hella, I chose to build a new theme.
