WooCommerce instead Wordpress CMS?
Attone
Attone posted this 08 June 2017
When I'm trying to start Themler in Wordpress CMS it actually loads up my themes in WooCommerce instead Wordpress and I can't export themes because I have got personal license so for Wordpress not WooCommerce.
Is this supposed to work like this?
When I'm trying to start Themler in Wordpress CMS it actually loads up my themes in WooCommerce instead Wordpress and I can't export themes because I have got personal license so for Wordpress not WooCommerce. Is this supposed to work like this?
Support Team posted this 09 June 2017
Does it happen on your hosted website? If so, is wooCommerce installed in your Wordpress?
Hello, Does it happen on your hosted website? If so, is wooCommerce installed in your Wordpress? Sincerely, Nettie, BillionDigital Team
Attone
Attone posted this 09 June 2017
Nope, it happens on themler for windows.
Did you create some new themes in Themler for Wordpress or imported them? If imported, where were the themes created initially - on your host?
Hello, Did you create some new themes in Themler for Wordpress or imported them? If imported, where were the themes created initially - on your host? Sincerely, Nettie, BillionDigital Team
Attone
this is what happens when I try to choose wordpress cms from the themler starting menu
when i'm trying to export the file as .zip it tells me i need woocommerce and that i need to choose the license
this is what happens when I try to choose wordpress cms from the themler starting menu when i'm trying to export the file as .zip it tells me i need woocommerce and that i need to choose the license
As I understand, Themler for wooCommerce is automatically opened while you select Themler for Wordpress. You don't have any themes created with Themler desktop, right? Please try completely uninstalling Themler, and check the box for "Remove CMS Content" in the process of installation. Then download and install Themler for Windows anew. Try to open Themler for Wordpress, create a new theme and export it. Please let us know the result.
Sincerel,y
Hello, As I understand, Themler for wooCommerce is automatically opened while you select Themler for Wordpress. You don't have any themes created with Themler desktop, right? Please try completely uninstalling Themler, and check the box for "Remove CMS Content" in the process of installation. Then download and install Themler for Windows anew. Try to open Themler for Wordpress, create a new theme and export it. Please let us know the result. Sincerel,y Nettie, BillionDigital Team
Attone
Checking the box "Remove CMS Content" during uninstalling Themler did a work.
Thanks for solving the problem
Checking the box "Remove CMS Content" during uninstalling Themler did a work. Thanks for solving the problem
Support Team posted this 12 June 2017
You are welcome! Please feel free to contact us in any other case. Sincerely, Nettie, BillionDigital Team
