Themler Issues
joshorthel
joshorthel posted this 09 June 2017
I have Themler, and havent used it for a while. Now when I try to open it, it does nothing.
9 Comments
Support Team posted this 09 June 2017
Could you please provide log file created with Themler Diagnostics Tool according to this instruction:
http://answers.themler.com/articles/13879/themler-desktop-troubleshooting#installation
Hello, Could you please provide log file created with Themler Diagnostics Tool according to this instruction: http://answers.themler.com/articles/13879/themler-desktop-troubleshooting#installation Thank you, Nettie, BillionDigital Team
joshorthel
It won't let me post the diagnostic, It's too long
DouzanStudio
DouzanStudio posted this 10 June 2017
Put it in (.text) file and attach it into the right side of comment box ----->
joshorthel
joshorthel posted this 12 June 2017
Attached file for diagnostic
Support Team posted this 13 June 2017
Thanks for the log file. Were there any changes in the system before the latest start of Themler? Please check date and time settings in the system, the date and time should be correct. Let us know if the issue is still present.
Hello, Thanks for the log file. Were there any changes in the system before the latest start of Themler? Please check date and time settings in the system, the date and time should be correct. Let us know if the issue is still present. Sincerely, Nettie, BillionDigital Team
joshorthel
joshorthel posted this 13 June 2017
I am not sure if there was. The last time I tried to start Themler was a couple of days ago. So, I am guessing there probably was.
Did you please check the settings in the system mentioned above? If so, please follow the steps below:
Hello, Did you please check the settings in the system mentioned above? If so, please follow the steps below: 1. Backup all theme folders somewhere on your computer if there are any. The path is shown in the Theme Management screen after selecting some CMS, for example, `C:\ProgramData\Themler\hd_data\themler_xxxxxxxxx\wordpress`. 2. Uninstall Themler completely and also check the box for "Remove all CMS content". 3. Check if the following folders are still present: C:\Program Files (x86)\Themler C:\ProgramData\Themler 4. If they exist, remove them. 5. Reboot the machine after uninstalling Themler, so that all Themler services are removed for sure. 6. Temporarily disable antivirus and firewall. 7. Download latest version of Themler for Windows from themler.com, install it and try to start with Themler for any CMS and create a theme. Please let us know the result. Sincerely, Nettie, BillionDigital Team
joshorthel
joshorthel posted this 19 June 2017
Looks like that worked. I guess I have to pay again, if I want to update it?
Support Team posted this 20 June 2017
Yes, please follow these steps to upgrade with discount:
1. Open http://themler.com/purchase and you will see on the top your expired subscription
2. Click "Upgrade" button next to it.
3. You will see the price for upgrade for your subscription.
Hello, Yes, please follow these steps to upgrade with discount: 1. Open http://themler.com/purchase and you will see on the top your expired subscription 2. Click "Upgrade" button next to it. 3. You will see the price for upgrade for your subscription. Sincerely, Nettie, BillionDigital Team
