Two side bars on the same side?
eleanor
eleanor posted this 13 June 2017
I have a client who I made an Artisteer template with the left and right side bars on the right hand side of her site.
I would like to upgrade the template to a Themler template but can't see how to achieve the same two side bars on the same side of the site.
Can you tell me how to achieve this?
Hi I have a client who I made an Artisteer template with the left and right side bars on the right hand side of her site. I would like to upgrade the template to a Themler template but can't see how to achieve the same two side bars on the same side of the site. Can you tell me how to achieve this? Thank you
Support Team posted this 13 June 2017
In Themler it works a bit different, but you may insert as many Joomla Module Positions as you need. So please try to put some container on the right, for example, Columns (with two columns in it) and put a Joomla Module Position into each column. Then you may need to adjust width of columns.
Hello, In Themler it works a bit different, but you may insert as many Joomla Module Positions as you need. So please try to put some container on the right, for example, Columns (with two columns in it) and put a Joomla Module Position into each column. Then you may need to adjust width of columns. Sincerely, Nettie, BillionDigital Team
eleanor
Oh, of course!!
thank you :)
Oh, of course!! thank you :)
You are welcome!
You are welcome! Sincerely, Nettie, BillionDigital Team
