html width
dragana
dragana posted this 13 June 2017
I want to set the html to full width. How/where do I do that?
Support Team posted this 14 June 2017
Do you mean HTML-control?
Each layout control has "Fluid" extension or "Fluid" Length.
But these options wok only if the control is not located inside other parent control or parent control has fluid length too. These options will not work inside Boxed or Wide parent containers.
Hi, Do you mean HTML-control? Each layout control has "Fluid" extension or "Fluid" Length. But these options wok only if the control is not located inside other parent control or parent control has fluid length too. These options will not work inside Boxed or Wide parent containers. Thank you, Olivia
dragana
dragana posted this 14 June 2017
So how/where can I change Fluid for Page?
> Hi, > > Do you mean HTML-control? > Each layout control has "Fluid" extension or "Fluid" Length. > But these options wok only if the control is not located inside other parent control or parent control has fluid length too. These options will not work inside Boxed or Wide parent containers. > > Thank you, > Olivia > So how/where can I change Fluid for Page?
thfischbach
thfischbach posted this 14 June 2017
Please, see attached file... :)
dragana
Thanks! I also changed width so the html frame got wider :)
