themler and woocommerce
piotr-mazik
piotr-mazik posted this 14 June 2017
Hello, I would like to know if there is a possibility of placing in themler such appearance for products in the woocommerce and for a single product because I would like to slightly change the shop to a friend. Below I am posting screenshots
Hello, I would like to know if there is a possibility of placing in themler such appearance for products in the woocommerce and for a single product because I would like to slightly change the shop to a friend. Below I am posting screenshots !pelny-produkt.png!!produkt-glowna.png!
Support Team posted this 14 June 2017
I think it could be possible. But please note that Themler does not create woocommerce custom fields (size selector, etc). If you know how to output all desired data without Themler theme we can help you in outputting this data with Themler theme.
But I suggest that you check the blank Themler theme with sample data on Themler Desktop to see the general styling and functionality of Themler shop controls. This part cannot be changed.
Hi, I think it could be possible. But please note that Themler does not create woocommerce custom fields (size selector, etc). If you know how to output all desired data without Themler theme we can help you in outputting this data with Themler theme. But I suggest that you check the blank Themler theme with sample data on Themler Desktop to see the general styling and functionality of Themler shop controls. This part cannot be changed. Please let us know if you have any further questions. Thank you, Olivia
piotr-mazik
piotr-mazik posted this 15 June 2017
Hi, what I was able to achieve this is a short one at http://e-goodnight.com/ there is created a shop with a plugin woocommerce and the simplest template themlera I did.
Support Team posted this 15 June 2017
You need to create such custom fields in WooCommerce settings, maybe WooCommerce forums will be helpful.
Hi, You need to create such custom fields in WooCommerce settings, maybe WooCommerce forums will be helpful. Sincerely, Hella
