Url "a" tag, link
Stagger Lee posted this 18 June 2017
I know it is maybe not so big work for your developers. Can you give us one new "display" option for links ?
So we can chose display: block for links. This way we coud make easy all containers, blocks, CMS Control clickable, not only link text.
Small option but would mean a lot.
Mores Styles - Link - Paragraph Options, somewhere under padding options.
I know it is maybe not so big work for your developers. Can you give us one new "display" option for links ? So we can chose display: block for links. This way we coud make easy all containers, blocks, CMS Control clickable, not only link text. Small option but would mean a lot. Mores Styles - Link - Paragraph Options, somewhere under padding options.
6 Comments
Support Team posted this 19 June 2017
You want to make everything clickable? OK, we'll consider your suggestion, for now that can be done manually probably with any container.
Hi, You want to make everything clickable? OK, we'll consider your suggestion, for now that can be done manually probably with any container. Sincerely, Hella
Stagger Lee posted this 19 June 2017
Yes Hella.
I mean not a big deal. In CSS part of Code control, or custom CSS file if any other block, you write something like this:
.bd-custom-block a {display: block;}
(dont remember now right name of class)
And it is all.
Just saying it is many, many, many steps when developing one webite. Option like this would make it more easy. :)
I remember I needed it many times before. When trying to imitate Bootstrap buttons in Code controls (when own PHP code is needed and standard Button options dont allow it). Real mental acrobatic. And we have other blocks and containers that can be designed/styled exactly as Bootstrap buttons. Themler already allows us to do it with all other options.
Hi Yes Hella. I mean not a big deal. In CSS part of Code control, or custom CSS file if any other block, you write something like this: **.bd-custom-block a {display: block;}** (dont remember now right name of class) And it is all. Just saying it is many, many, many steps when developing one webite. Option like this would make it more easy. :) I remember I needed it many times before. When trying to imitate Bootstrap buttons in Code controls (when own PHP code is needed and standard Button options dont allow it). Real mental acrobatic. And we have other blocks and containers that can be designed/styled exactly as Bootstrap buttons. Themler already allows us to do it with all other options.
i often do it with Bootstrap "List Group" ans "Panels" (whole clickable), manual code.
But, you know. Bootstrap has some very hard rules regarding them, and some default styling is applied, you cannot change and avoid.
i often do it with Bootstrap "List Group" ans "Panels" (whole clickable), manual code. But, you know. Bootstrap has some very hard rules regarding them, and some default styling is applied, you cannot change and avoid.
Maybe I'm missing something, but for each control you can set the display option to block in the right panel.
Hi, Maybe I'm missing something, but for each control you can set the display option to block in the right panel. Sincerely, Hella
I know. Tried and doesnt apply to links inside. Link is still only clickable on text width and height, not whole block.
Thanks. I see now. The suggestion is in our wish list.
Thanks. I see now. The suggestion is in our wish list. Sincerely, Hella
