quantity discount Virtuemart price_quantity_start and price_quantity_end + product_price
Boekhoorn.nl
Boekhoorn.nl posted this 19 June 2017
I have the following in VirtueMart
An article with price 100
But is you buy 10 the price will be 90 and if you buy 20 the price will be 80 so i use quantity discount
This works fine in VM
Now i want to display a "sheet" with these quantity discounts next to the price so people know how much to order to get the next discount.
How do i set this up in my template.
Hi, I have the following in VirtueMart An article with price 100 But is you buy 10 the price will be 90 and if you buy 20 the price will be 80 so i use quantity discount This works fine in VM Now i want to display a "sheet" with these quantity discounts next to the price so people know how much to order to get the next discount. How do i set this up in my template.
Support Team posted this 20 June 2017
Unfortunately theme itself does not provide such option.
Do you have an example of what exactly you want ti achieve?
In general, you can try using VM custom fields and output them using Themler Product Variation control.
Hi, Unfortunately theme itself does not provide such option. Do you have an example of what exactly you want ti achieve? In general, you can try using VM custom fields and output them using Themler Product Variation control. Thank you, Olivia
Boekhoorn.nl
Boekhoorn.nl posted this 17 August 2017
Hi.
I have used your advice to use Variation control
That helped me a lot with other custom fields.
but,,,
My issue stays :(
I have products in VM on wich you can get a volume discount.
So if you order 1 you pay 10 and if you order 5 you pay 8 (for example)
These prices are setup in VM but how to show on the template at what number of items you get a discount.
What i want my shopper to see is the following
PRODUCT
Price 100 for 1 to 10 items
Price 90 for 11 to 20 items
Price 80 for 12 to 50 items (and so on)
How to do this ?
Hi. I have used your advice to use Variation control That helped me a lot with other custom fields. but,,, My issue stays :( I have products in VM on wich you can get a volume discount. So if you order 1 you pay 10 and if you order 5 you pay 8 (for example) These prices are setup in VM but how to show on the template at what number of items you get a discount. What i want my shopper to see is the following PRODUCT Price 100 for 1 to 10 items Price 90 for 11 to 20 items Price 80 for 12 to 50 items (and so on) How to do this ?
How would you do this with any other joomla theme? Please note that Themler theme does not provide own VM features. It uses built in VM functionality and adjusts its appearance only.
If this is just one products you can add it to the product description, for example.
Hi, How would you do this with any other joomla theme? Please note that Themler theme does not provide own VM features. It uses built in VM functionality and adjusts its appearance only. If this is just one products you can add it to the product description, for example. Thank you, Olivia
