Using Page TEMPLATE
michel.habraken
michel.habraken posted this 19 June 2017
In your manual you say that you can make a template 'PAGE' by turning settings on 'HIDE' in Joomla.
http://answers.themler.com/articles/36343/how-to-work-with-templates-in-joomla-themes
You say we have to do this in the MENU settings, but then it still is not working, only when you ALSO change it with the ARTICLE OPTIONS, then it works. Is that normal? For every normal page that I want, I have to change all the settings in the Menu item including the Article options.
Hi, In your manual you say that you can make a template 'PAGE' by turning settings on 'HIDE' in Joomla. http://answers.themler.com/articles/36343/how-to-work-with-templates-in-joomla-themes You say we have to do this in the MENU settings, but then it still is not working, only when you ALSO change it with the ARTICLE OPTIONS, then it works. Is that normal? For every normal page that I want, I have to change all the settings in the Menu item including the Article options.
Support Team posted this 19 June 2017
Looks strange as the menu item options should override the article options. Make sure that you set Hide value and not the Use global values.
Also with the Joomla default theme do you see what is set in the article options instead of what is set in the menu item options?
Hi, Looks strange as the menu item options should override the article options. Make sure that you set Hide value and not the Use global values. Also with the Joomla default theme do you see what is set in the article options instead of what is set in the menu item options? Sincerely, Hella
michel.habraken
michel.habraken posted this 20 June 2017
Hi Hella,
I checked it for you, but it is the same. I checked with default theme Joomla as also with Themler theme Joomla.
I work with version Joomla 3.7.2.
In the printscreens, everything is Global, but it is to show you, that you have same choices. When I select the choices from the manual in the MENU OPTIONS, the template will stay as Post template. As soon as i change the ARTICLE OPTIONS with the same selections as from the MENU, than the page in Themler will be seen as PAGE TEMPLATE.
Michel
Attachements, printscreens Menu and Article options
Hi Hella, I checked it for you, but it is the same. I checked with default theme Joomla as also with Themler theme Joomla. I work with version Joomla 3.7.2. In the printscreens, everything is Global, but it is to show you, that you have same choices. When I select the choices from the manual in the MENU OPTIONS, the template will stay as Post template. As soon as i change the ARTICLE OPTIONS with the same selections as from the MENU, than the page in Themler will be seen as PAGE TEMPLATE. Sincerely, Michel Attachements, printscreens Menu and Article options !MenuItemOptions-defaultThemeJoomla.JPG! !ArticletemOptions-defaultThemeJoomla.JPG! !MenuItemOptions-ThemlerThemeJoomla.JPG! !ArticletemOptions-ThemlerThemeJoomla.JPG!
Support Team posted this 20 June 2017
Do not set Use Global option in the Menu options, set them to Hide. If that does not help, provide an access to the site back end and point to the problem menu item.
Hi, Do not set Use Global option in the Menu options, set them to Hide. If that does not help, provide an access to the site back end and point to the problem menu item. Sincerely, Hella
michel.habraken
Hi Hella,
That's what I said, I showed you only the possible options, that you could see, that they are the same.
Unfortunately I cannot give you access to the backend, cause I am working on local host before publishing the website.
Gr. Michel
Hi Hella, That's what I said, I showed you only the possible options, that you could see, that they are the same. Unfortunately I cannot give you access to the backend, cause I am working on local host before publishing the website. Gr. Michel
Then use the Hide values in the options, maybe that will work fine later. The problem might be somewhere in the Joomla settings as it works the same with the default Joomla theme. Maybe you could wait till you get online and then provide an access to the live site if the issue persists.
Hi, Then use the Hide values in the options, maybe that will work fine later. The problem might be somewhere in the Joomla settings as it works the same with the default Joomla theme. Maybe you could wait till you get online and then provide an access to the live site if the issue persists. Sincerely, Hella
