how to add rtl direction in same theme (DRUPAL)
mostafax222
mostafax222 posted this 21 June 2017
i want to make multilanguage website ( english - arabic ) i want when change language change direction.
Support Team posted this 23 June 2017
There is no such possibility. One theme cannot work with two text directions. You can create two different themes and use some plug-in that will switch templates when the user changes language.
Hi, There is no such possibility. One theme cannot work with two text directions. You can create two different themes and use some plug-in that will switch templates when the user changes language. Sincerely, Hella
mostafax222
mostafax222 posted this 24 June 2017
can add this feature in future
Support Team posted this 26 June 2017
I'll add this request to our wish list for possible future implementations.
Hi, I'll add this request to our wish list for possible future implementations. Sincerely, Hella
Web IT Solutions LLP
Web IT Solutions LLP posted this 12 June 2018
Any updates on this please ?
Suffian Ahmed
Any updates on this please ? Regards Suffian Ahmed
Support Team posted this 12 June 2018
Unfortunately there are no new.
Theme direction is not just one property. Therefore if you want the theme to look properly in both directions you need two themes and each one should be configured in the way you want.
Hi, Unfortunately there are no new. Theme direction is not just one property. Therefore if you want the theme to look properly in both directions you need two themes and each one should be configured in the way you want. Thank you, Olivia
