Woocommerce product variation image not showing
Rune
Rune posted this 22 June 2017
When I set a specific image to a variation (in this case a color variation) the variation image are not showing in the place of the product image in "product detail"-overview in the shop.
  • what to do?
Hi When I set a specific image to a variation (in this case a color variation) the variation image are not showing in the place of the product image in "product detail"-overview in the shop. - what to do?
16 Comments
Support Team posted this 22 June 2017
Does it work fine with the default WP theme? If yes, please provide a link to the page where we could see the issue.
Hi, Does it work fine with the default WP theme? If yes, please provide a link to the page where we could see the issue. Sincerely, Hella
Rune
Yes. It work fine with Twenty Seventeen.
Take a look https://bymp.dk/produkt/testprodukt/
Yes. It work fine with Twenty Seventeen. Take a look https://bymp.dk/produkt/testprodukt/
Support Team posted this 23 June 2017
This issue should be fixed in the future Themler updates.
Hi, This issue should be fixed in the future Themler updates. Thank you, Olivia
Rune
Rune posted this 23 June 2017
Sounds great!
Can you give me a hint for a fix? My deadline are probably sooner than your update.
Sounds great! Can you give me a hint for a fix? My deadline are probably sooner than your update.
Please try the following suggestion:
  • open includes\product_overview_1.php file
  • find the following code:
<div class=" bd-productimage-6 ">
<div class="zoom-container images">
<?php if ( has_post_thumbnail() ) : ?>
<a itemprop="image" href="<?php echo wp_get_attachment_url( get_post_thumbnail_id() ); ?>" class="zoom" data-rel="prettyPhoto[product-gallery]" rel="thumbnails" title="<?php echo get_the_title( get_post_thumbnail_id() ); ?>">
<?php
global $post;
remove_action('begin_fetch_post_thumbnail_html', '_wp_post_thumbnail_class_filter_add'); // disable 'wp-post-image' class
echo get_the_post_thumbnail( $post->ID, apply_filters( 'single_product_large_thumbnail_size', 'shop_single' ), array('class' => ' bd-imagestyles') );
add_action('begin_fetch_post_thumbnail_html', '_wp_post_thumbnail_class_filter_add');
</a>
<?php else : ?>
<img class=' bd-imagestyles' src="<?php echo woocommerce_placeholder_img_src(); ?>" alt="Placeholder" />
<?php endif; ?>
</div>
</div>
  • add the following line before the code above:
<?php if (version_compare(WC_VERSION, '3.0.0', '<')) { ?>
  • and add this code after the code above:
<?php } else {
global $post;
$post_thumbnail_id = get_post_thumbnail_id($post->ID);
$full_size_image = wp_get_attachment_image_src($post_thumbnail_id, 'full');
$thumbnail_post = get_post($post_thumbnail_id);
$image_title = $thumbnail_post->post_content;
<div class=" bd-productimage-6 images woocommerce-product-gallery__wrapper">
<?php
$attributes = array(
'title' => $image_title,
'data-src' => $full_size_image[0],
'data-large_image' => $full_size_image[0],
'data-large_image_width' => $full_size_image[1],
'data-large_image_height' => $full_size_image[2],
'class' => ' bd-imagestyles',
if (has_post_thumbnail()) {
$html = '<div data-thumb="' . get_the_post_thumbnail_url($post->ID, 'shop_thumbnail') . '" class="woocommerce-product-gallery__image zoom-container"><a href="' . esc_url($full_size_image[0]) . '">';
$html .= get_the_post_thumbnail($post->ID, 'shop_single', $attributes);
$html .= '</a></div>';
} else {
$html = '<div class="woocommerce-product-gallery__image--placeholder">';
$html .= sprintf('<img src="%s" alt="%s" class=" bd-imagestyles wp-post-image" />', esc_url(wc_placeholder_img_src()), esc_html__('Awaiting product image', 'woocommerce'));
$html .= '</div>';
echo apply_filters('woocommerce_single_product_image_thumbnail_html', $html, get_post_thumbnail_id($post->ID));
</div>
<?php } ?>
In other works you need to wrap the original Product image code into the provided cycle.
Hi, Please try the following suggestion: - open includes\product_overview_1.php file - find the following code: `<div class=" bd-productimage-6 "> <div class="zoom-container images"> <?php if ( has_post_thumbnail() ) : ?> <a itemprop="image" href="<?php echo wp_get_attachment_url( get_post_thumbnail_id() ); ?>" class="zoom" data-rel="prettyPhoto[product-gallery]" rel="thumbnails" title="<?php echo get_the_title( get_post_thumbnail_id() ); ?>"> <?php global $post; remove_action('begin_fetch_post_thumbnail_html', '_wp_post_thumbnail_class_filter_add'); // disable 'wp-post-image' class // echo get_the_post_thumbnail( $post->ID, apply_filters( 'single_product_large_thumbnail_size', 'shop_single' ), array('class' => ' bd-imagestyles') ); add_action('begin_fetch_post_thumbnail_html', '_wp_post_thumbnail_class_filter_add'); ?> </a> <?php else : ?> <img class=' bd-imagestyles' src="<?php echo woocommerce_placeholder_img_src(); ?>" alt="Placeholder" /> <?php endif; ?> </div> </div>` - add the following line before the code above: `<?php if (version_compare(WC_VERSION, '3.0.0', '<')) { ?>` - and add this code after the code above: `<?php } else {` ` global $post; $post_thumbnail_id = get_post_thumbnail_id($post->ID); $full_size_image = wp_get_attachment_image_src($post_thumbnail_id, 'full'); $thumbnail_post = get_post($post_thumbnail_id); $image_title = $thumbnail_post->post_content; ?>` `<div class=" bd-productimage-6 images woocommerce-product-gallery__wrapper"> <?php $attributes = array( 'title' => $image_title, 'data-src' => $full_size_image[0], 'data-large_image' => $full_size_image[0], 'data-large_image_width' => $full_size_image[1], 'data-large_image_height' => $full_size_image[2], 'class' => ' bd-imagestyles', );` `if (has_post_thumbnail()) { $html = '<div data-thumb="' . get_the_post_thumbnail_url($post->ID, 'shop_thumbnail') . '" class="woocommerce-product-gallery__image zoom-container"><a href="' . esc_url($full_size_image[0]) . '">'; $html .= get_the_post_thumbnail($post->ID, 'shop_single', $attributes); $html .= '</a></div>'; } else { $html = '<div class="woocommerce-product-gallery__image--placeholder">'; $html .= sprintf('<img src="%s" alt="%s" class=" bd-imagestyles wp-post-image" />', esc_url(wc_placeholder_img_src()), esc_html__('Awaiting product image', 'woocommerce')); $html .= '</div>'; }` `echo apply_filters('woocommerce_single_product_image_thumbnail_html', $html, get_post_thumbnail_id($post->ID)); ?> </div>` `<?php } ?>` In other works you need to wrap the original Product image code into the provided cycle. Please let us know the result. Thank you, Olivia
Rune
It worked... And screw up the hole layout
Could you please provide us with the screenshot that demonstrates the new issue?
Hi, Could you please provide us with the screenshot that demonstrates the new issue? Thank you, Olivia
Rune
Is Solution
Ah. Found the problem. It works fine now! :)
Great!
Please let us know if you have any other questions/issues.
Also, pleaes note that each saving theme in Themler may erase custom changes. I suggest that you make the copy of the edited file and keep it somewhere.
Great! Please let us know if you have any other questions/issues. Also, pleaes note that each saving theme in Themler may erase custom changes. I suggest that you make the copy of the edited file and keep it somewhere. Thank you, Olivia
Sem
Sem posted this 28 July 2017
Hello I tried this solution for me. It shows 2 main images on the product page. Can you help me please with this
Support Team posted this 30 July 2017
Hi Sem,
Could you please create a new private topic and attach the problem theme with code modifications.
Hi Sem, Could you please create a new private topic and attach the problem theme with code modifications. Thank you, Olivia
Pbannerman13
Pbannerman13 posted this 09 September 2017
I'm having the exact same problem, but the code above didn't work for me.
Support Team posted this 11 September 2017
Pbannerman13.
I've answered you in your private topic about this issue.
Pbannerman13. I've answered you in your private topic about this issue. Thank you, Olivia
Seagull
Seagull posted this 15 November 2017
Hello, was this ever fixed because a client just emailed me about it yesterday and I couldn't workout what had broken it. I have tried the website with the Storefront theme by Woothemes and everything works correctly in that.
Best regards,
Angela
Hello, was this ever fixed because a client just emailed me about it yesterday and I couldn't workout what had broken it. I have tried the website with the Storefront theme by Woothemes and everything works correctly in that. Best regards, Angela
Seagull
Hmm, it seems not as I added the above code and it now works, but what happens when the next Themler update or theme update writes over it? As a known and quite serious bug (for an ecommerce theme) this needs fixing asap.
Support Team posted this 15 November 2017
The fix will be included into the next Themler update.
Hi, The fix will be included into the next Themler update. Thank you, Olivia
