Disable zoom on product image and enable Lighbox
info69
info69 posted this 22 June 2017
I like to disable the cloudzoom and use lightbox on my product images for a customer.
The products are send in by a extern system and the pictures have determined dimensions. The cloudzoom is not what the client wants and when I remove the cloudzoom there is no ligtbox effect all though this is on in Themler.
With no zoom, if you click on the picture it displays the picture on url of the picture. No lightbox display. I also tryed to use a external plugin but they dont work with the template.
Site url http://www.blueindustrystore.eu/
Henk Kuiper
Henk Kuiper Webs
Hello, I like to disable the cloudzoom and use lightbox on my product images for a customer. The products are send in by a extern system and the pictures have determined dimensions. The cloudzoom is not what the client wants and when I remove the cloudzoom there is no ligtbox effect all though this is on in Themler. With no zoom, if you click on the picture it displays the picture on url of the picture. No lightbox display. I also tryed to use a external plugin but they dont work with the template. Site url http://www.blueindustrystore.eu/ Sincerely, Henk Kuiper Henk Kuiper Webs
9 Comments
Support Team posted this 22 June 2017
Try to add this line of code under the Home >> Settings >> CMS Code:
update_option('woocommerce_enable_lightbox', 'no');
Then save the theme so the code will run and then you can remove it.
Hi, Try to add this line of code under the Home >> Settings >> CMS Code: update_option('woocommerce_enable_lightbox', 'no'); Then save the theme so the code will run and then you can remove it. Sincerely, Hella
info69
Hello Hella,
This is not clear to me what do I need to remove?
Henk Kuiper
Henk Kuiper Webs
Hello Hella, This is not clear to me what do I need to remove? Sincerely, Henk Kuiper Henk Kuiper Webs
You can remove this line of code when it once run on the site. So when you add it and then save the theme and it is applied to the site, the code will be executed. After that you can remove it from the CMS Code area inside Themler as it needs to be executed only once.
You can remove this line of code when it once run on the site. So when you add it and then save the theme and it is applied to the site, the code will be executed. After that you can remove it from the CMS Code area inside Themler as it needs to be executed only once. Sincerely, Hella
info69
Hello Hella,
This isn't working. There is still no lightbox I need the lightbox to work.
I disabeled the Cloudzoom used the code but the lightbox is still not working
Henk Kuiper
Henk Kuiper Webs
Hello Hella, This isn't working. There is still no lightbox I need the lightbox to work. I disabeled the Cloudzoom used the code but the lightbox is still not working Sincerely, Henk Kuiper Henk Kuiper Webs
info69
info69 posted this 29 June 2017
Its a week ago sins my last request about this and the fact that the posted code doen't work. I stil did not get a anwser or any other response.
It looks like no one has the answer to the probleem and the Themler team is not interessted in solving the issue.
Henk Kuiper
Henk Kuiper Webs
Hello, Its a week ago sins my last request about this and the fact that the posted code doen't work. I stil did not get a anwser or any other response. It looks like no one has the answer to the probleem and the Themler team is not interessted in solving the issue. Sincerely, Henk Kuiper Henk Kuiper Webs
Support Team posted this 30 June 2017
Sorry for the delay.
Unfortunately CloudZoom effect cannot be disabled or switched with lightbox.
Hella provided you with solution for different problem related to CloudZoom effect. We apologize for the inconvenience.
Hi, Sorry for the delay. Unfortunately CloudZoom effect cannot be disabled or switched with lightbox. Hella provided you with solution for different problem related to CloudZoom effect. We apologize for the inconvenience. Thank you, Olivia
info69
info69 posted this 30 June 2017
Hello Olivia,
I see this is a issue sins 2015 and still hasen't bin resolved. This is for me not accepteble and it means to me that you don't take the issue serious. The issue pops up multiple times and is still not resolved.
I wil be forced to no longer use themler for my woocommerce sites an change to a other template builder like Divi
Henk Kuiper
Henk Kuiper Webs
Hello Olivia, I see this is a issue sins 2015 and still hasen't bin resolved. This is for me not accepteble and it means to me that you don't take the issue serious. The issue pops up multiple times and is still not resolved. I wil be forced to no longer use themler for my woocommerce sites an change to a other template builder like Divi Sincerely, Henk Kuiper Henk Kuiper Webs
Unfortunately Themler Product Image supports CloudZoom only.
As alternative you can try to output product images in a standard way using CMS Code control. In this case the third-party plugins which create effects for product images may work. But I cannot guarantee.
Hi, Unfortunately Themler Product Image supports CloudZoom only. As alternative you can try to output product images in a standard way using CMS Code control. In this case the third-party plugins which create effects for product images may work. But I cannot guarantee. Thank you, Olivia
info1938
info1938 posted this 08 May 2019
It's really pathetic...
