how can i create more spacing in between menu?
fgl_aj
fgl_aj posted this 26 June 2017
how can i create more spacing in between menu? basicly i want them to spread out more..thanks
Support Team posted this 26 June 2017
You mean the distance between the menu items? You can set the menu item margin or padding depending on where you want the space to appear. Between the items or within the item to make it bigger.
Hi, You mean the distance between the menu items? You can set the menu item margin or padding depending on where you want the space to appear. Between the items or within the item to make it bigger. Sincerely, Hella
fgl_aj
fgl_aj posted this 27 June 2017
got it thanks!
got it thanks!
Support Team posted this 27 June 2017
You are welcome. Let us know if you need any further help.
You are welcome. Let us know if you need any further help. Sincerely, Hella
