Special fields aren't show in the purchase order
arawolf
arawolf posted this 27 June 2017
On a webshop some articles have special fields. But on the purchase order the choises of the special fields aren't show.
the domain : dkdecor.be
On a webshop some articles have special fields. But on the purchase order the choises of the special fields aren't show. the domain : dkdecor.be
9 Comments
Support Team posted this 27 June 2017
Does the issue happen is you add product to the cart with default joomla theme activated?
Could you please provide a few screenshots that demonstrate the difference between Themler and joomla themes.
Hi, Does the issue happen is you add product to the cart with default joomla theme activated? Could you please provide a few screenshots that demonstrate the difference between Themler and joomla themes. Thank you, Olivia
arawolf
When i change the template to a standaard joomla theme ex BEEZ the special fields aren't show at all. Even not on the article page. Maybe you cabn see for yourself.
Thnx
When i change the template to a standaard joomla theme ex BEEZ the special fields aren't show at all. Even not on the article page. Maybe you cabn see for yourself. Thnx
arawolf
arawolf posted this 28 June 2017
i also get many javescript errors when the themler template is online.
arawolf
I see also that the productdetails are show twice on the same page !
Support Team posted this 28 June 2017
Each custom field has "layout position" property which is similar to joomla module positions.
You need to use a proper position name with beez theme. I do not know what position name this theme uses. The protostar theme uses "addtocart" position for all custom fields.
You have not reported this issue previously. At what monets the issue started to appear? Most probably it is related to thord-party plugin/module you enabled on the page. Unfortunately we cannot sau motre without live link to the problem page.
Hi, > When i change the template to a standaard joomla theme ex BEEZ the special fields aren't show at all. Even not on the article page. Maybe you cabn see for yourself. Each custom field has "layout position" property which is similar to joomla module positions. You need to use a proper position name with beez theme. I do not know what position name this theme uses. The protostar theme uses "addtocart" position for all custom fields. > I see also that the productdetails are show twice on the same page ! You have not reported this issue previously. At what monets the issue started to appear? Most probably it is related to thord-party plugin/module you enabled on the page. Unfortunately we cannot sau motre without live link to the problem page. Thank you, Olivia
arawolf
Olivia maybe i can give you inlogacces, the problem of the 2 productdetails in one page appears when i set the site online.
arawolf
Olivia news. I maked some changes to the template and most of the special fields are showing and working. I see only 1 productdetail, so that is fine. Only the one special field isn't show. The field where the costumer have to put in some text.
arawolf
arawolf posted this 29 June 2017
Olivia, there was something wrong with the template. Some fixes make the template back on track. Seems solved
Support Team posted this 29 June 2017
Sorry for the delay in responding. Nice to hear that it is solved now. Let us know if you need our further help.
Hi, Sorry for the delay in responding. Nice to hear that it is solved now. Let us know if you need our further help. Sincerely, Hella
