Add more options for Meta Tags in HTML5 sites
DaveOzric
DaveOzric posted this 30 June 2017
Hello, as I work with more and more sites using the HTML5 portion of your software I wish you could add more options for the meta tags and the whole page property area. While I love the fact you can add custom head elements in the editor some defined options would be nice.
Specifically the meta description as a field would be very nice. SEO wise this is a big deal to have for CTR. It's kind of a pain to do these all manually.
Also can you add some way to see more space on the fields. Drag out the side or have the page properties be the whole screen or something. Can't see much now the way it is. Perhaps a popup like the Additional HEAD HTML option does.
Hello, as I work with more and more sites using the HTML5 portion of your software I wish you could add more options for the meta tags and the whole page property area. While I love the fact you can add custom head elements in the editor some defined options would be nice. Specifically the meta description as a field would be very nice. SEO wise this is a big deal to have for CTR. It's kind of a pain to do these all manually. Also can you add some way to see more space on the fields. Drag out the side or have the page properties be the whole screen or something. Can't see much now the way it is. Perhaps a popup like the Additional HEAD HTML option does. Thank you !2017-06-30-162103.jpg!
6 Comments
DaveOzric
DaveOzric posted this 12 August 2017
No takers?
Themler, can you make this a popup like the custom head and css options so there is a larger area to work on this?
Also, what is the "Custom URL" for?
No takers? Themler, can you make this a popup like the custom head and css options so there is a larger area to work on this? Also, what is the "Custom URL" for? Thanks
Support Team posted this 12 August 2017
Thanks for the suggestion.
The Custom URL option allows to specify any URL to which that menu item will link. It may be also set to # to make the menu item work as the separator.
Hi, Thanks for the suggestion. The *Custom URL* option allows to specify any URL to which that menu item will link. It may be also set to `#` to make the menu item work as the separator. Sincerely, Hella
DaveOzric
DaveOzric posted this 14 March 2018
Is there any possibility this can be expanded for ease of use. SEO is so very important and these settings are so difficult to work with. Any improvement is going to be helpful.
At least make it so I can see more of the fields.
Is there any possibility this can be expanded for ease of use. SEO is so very important and these settings are so difficult to work with. Any improvement is going to be helpful. At least make it so I can see more of the fields. Thanks
Support Team posted this 14 March 2018
We added this request to our wish list previously but I cannot say whether this improvement will be implemented or not, unfortunately.
The larger areas require a lot of more space which will make the dialog quite heavier in use.
Hi, We added this request to our wish list previously but I cannot say whether this improvement will be implemented or not, unfortunately. The larger areas require a lot of more space which will make the dialog quite heavier in use. Thank you, Olivia
DaveOzric
I will keep checking in to see. It's just a huge pain to work with this now but I only have a small % of html sites. Still worth it.
I will keep checking in to see. It's just a huge pain to work with this now but I only have a small % of html sites. Still worth it. Thanks
Nancy Miller
Nancy Miller posted this 15 March 2018
Hi Dave
Thanks for sharing this useful information
Hi Dave Thanks for sharing this useful information
