Translate "Cart"
sdbb
sdbb posted this 03 July 2017
where can i translate the word "Cart" next to the shopping basket in header?
Hi where can i translate the word "Cart" next to the shopping basket in header?
8 Comments
Support Team posted this 06 July 2017
Could you please try adding the following code to the Themler Settings >> CMS Code:
add_filter( 'gettext', 'wps_translate_words_array' );
add_filter( 'ngettext', 'wps_translate_words_array' );
function wps_translate_words_array( $translated ) {
$words = array(
// 'word to translate' = > 'translation'
'Cart (%s)' => 'ADD TRANSLATION HERE (%s)',
$translated = str_ireplace( array_keys($words), $words, $translated );
return $translated;
It should help. Looks like you do not have this key in the translation files.
Hi, Could you please try adding the following code to the Themler Settings >> CMS Code: `add_filter( 'gettext', 'wps_translate_words_array' ); add_filter( 'ngettext', 'wps_translate_words_array' ); function wps_translate_words_array( $translated ) { $words = array( // 'word to translate' = > 'translation' 'Cart (%s)' => 'ADD TRANSLATION HERE (%s)', ); $translated = str_ireplace( array_keys($words), $words, $translated ); return $translated; }` It should help. Looks like you do not have this key in the translation files. Thank you, Olivia
Vaidas B
Vaidas B posted this 20 December 2017
I am new in themler. Where to find Themler Sttings>> CMS Code to put it?
$words = array(
return $translated;
Hello, I am new in themler. Where to find Themler Sttings>> CMS Code to put it? Thanks > Hi, > > Could you please try adding the following code to the Themler Settings >> CMS Code: > > `add_filter( 'gettext', 'wps_translate_words_array' ); > add_filter( 'ngettext', 'wps_translate_words_array' ); > function wps_translate_words_array( $translated ) { > $words = array( > // 'word to translate' = > 'translation' > 'Cart (%s)' => 'ADD TRANSLATION HERE (%s)', > ); > $translated = str_ireplace( array_keys($words), $words, $translated ); > return $translated; > }` > > It should help. Looks like you do not have this key in the translation files. > > Thank you, > Olivia
Vaidas B
I find out where this CMS Code, but it didn't helped to translate "Cart" next to basket
$words = array(
return $translated;
Hi, I find out where this CMS Code, but it didn't helped to translate "Cart" next to basket > Hello, > I am new in themler. Where to find Themler Sttings>> CMS Code to put it? > Thanks > > > Hi, > > > > Could you please try adding the following code to the Themler Settings >> CMS Code: > > > > `add_filter( 'gettext', 'wps_translate_words_array' ); > > add_filter( 'ngettext', 'wps_translate_words_array' ); > > function wps_translate_words_array( $translated ) { > > $words = array( > > // 'word to translate' = > 'translation' > > 'Cart (%s)' => 'ADD TRANSLATION HERE (%s)', > > ); > > $translated = str_ireplace( array_keys($words), $words, $translated ); > > return $translated; > > }` > > > > It should help. Looks like you do not have this key in the translation files. > > > > Thank you, > > Olivia
Vaidas B
It helped,
thanks
It helped, thanks
Support Team posted this 20 December 2017
Vaidas B
but still is a problem. Translation apears only then the product is added. If cart is empty, no translation and the text is "Cart"
Could you please help to solve this :)
Hi, but still is a problem. Translation apears only then the product is added. If cart is empty, no translation and the text is "Cart" Could you please help to solve this :) Thanks
Support Team posted this 22 December 2017
The 'Cart (%s)' and 'Cart' are two different translation keys. Please add translations for both.
Hi, The `'Cart (%s)'` and `'Cart'` are two different translation keys. Please add translations for both. Thank you, Olivia
Vaidas B
Vaidas B posted this 29 December 2017
Thank you Olivia :)
Thank you Olivia :)
