System fonts
christophe39
christophe39 posted this 04 July 2017
In my installation, the system fonts isn't activate. A solution ?
Thank you.
Christophe Mathéi
Hello, In my installation, the system fonts isn't activate. A solution ? Thank you. Christophe Mathéi
Support Team posted this 04 July 2017
Hello Christophe,
Please try enabling Flash in your browser. For example, to enable it in Chrome:
https://support.google.com/chrome/answer/6213033?hl=en
Or try to open the theme in Firefox and enable Flash there. You may need to allow Flash several times when the theme is loaded.
Hello Christophe, Please try enabling Flash in your browser. For example, to enable it in Chrome: https://support.google.com/chrome/answer/6213033?hl=en Or try to open the theme in Firefox and enable Flash there. You may need to allow Flash several times when the theme is loaded. Sincerely, Nettie, BillionDigital Team
christophe39
christophe39 posted this 05 July 2017
I deactivated flash on Google, it corrects nothing. I made out a will on safari and on firefox the error is also present. A solution?
Christophe.
Hello, I deactivated flash on Google, it corrects nothing. I made out a will on safari and on firefox the error is also present. A solution? Thank you, Christophe.
Support Team posted this 05 July 2017
Hello Christophe,
The point is to enable Flash or allow running Flash plugin. Looks like the policies regarding Flash have been changed in main browsers recently. For me Chrome is blocking Flash despite of allowing it in Settings. As a possible workaround, try opening the theme in Firefox at least for selecting a system font. Firefox tries blocking Flash, as it is outdated, but it also doesn't allow updating the Flash plugin considering it vulnerable. And this is possibly the reason it cannot be activated globally in Firefox settings. But it is possible to enable the outdated one when opening a particular theme in Firefox. The point is to allow the plugin several times (4 times) before it is finally allowed. Please try to follow the same steps:
  1. Open the theme in Themler using Firefox. You will see the first warning:
    Click "Allow".
  2. The second warning:
    Click "Allow and Remember".
  3. The third warning:
    Click "Allow".
  4. The final warning:
    Click "Continue Allowing".
The page is refreshed.
Hello Christophe, The point is to enable Flash or allow running Flash plugin. Looks like the policies regarding Flash have been changed in main browsers recently. For me Chrome is blocking Flash despite of allowing it in Settings. As a possible workaround, try opening the theme in Firefox at least for selecting a system font. Firefox tries blocking Flash, as it is outdated, but it also doesn't allow updating the Flash plugin considering it vulnerable. And this is possibly the reason it cannot be activated globally in Firefox settings. But it is possible to enable the outdated one when opening a particular theme in Firefox. The point is to **allow the plugin several times (4 times) before it is finally allowed**. Please try to follow the same steps: 1. Open the theme in Themler using Firefox. You will see the first warning: !i442.png! Click "Allow". 2. The second warning: !i443.png! Click "Allow and Remember". 3. The third warning: !i444.png! Click "Allow". 4. The final warning: !i445.png! Click "Continue Allowing". The page is refreshed. Sincerely, Nettie, BillionDigital Team
