Science Laboratory Not working
Mark Holland
Mark Holland posted this 19 August 2014
"Science Laboratory" is not working i get the follwing error when i try and install:
There was an error uploading this file to the server.
Useing Joomla! 2.5.24
Artisteer 4.2.0.60623 SE
Other templates upload fine.
Thanks Mark Holland
Hi, "Science Laboratory" is not working i get the follwing error when i try and install: There was an error uploading this file to the server. Useing Joomla! 2.5.24 Artisteer 4.2.0.60623 SE Other templates upload fine. Thanks Mark Holland
Support Team posted this 19 August 2014
Hello Mark,
Thanks for reporting this issue - we will investigate it as soon as possible.
Best regards,
Tammy
Hello Mark, Thanks for reporting this issue - we will investigate it as soon as possible. Best regards, Tammy
Support Team posted this 20 August 2014
Hi Mark,
I've checked the attached template and could successfully install it in my test Joomla 2.5.
The issue on your end could be cuased by the template size - it's almost 3mB so you need to check to allow uploading packages with a size more than 2mb in your php.ini file.
Please read this forum thread for more information:
http://forum.joomla.org/viewtopic.php?p=1556804
Best regards,
Tammy
Hi Mark, I've checked the attached template and could successfully install it in my test Joomla 2.5. The issue on your end could be cuased by the template size - it's almost 3mB so you need to check to allow uploading packages with a size more than 2mb in your php.ini file. Please read this forum thread for more information: http://forum.joomla.org/viewtopic.php?p=1556804 Best regards, Tammy
